Page 7 of 25 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 LastLast
Results 91 to 105 of 362
  1. #91
    Feb 2020
    MinneSnowda
    Knock on wood... those have worked for me so far... lol They ohm good. I'll check into ordering another set. I'm not opposed to having a couple spares (and a spare coil) on the boat
  2. #92
    Copper, end to end continuity only. Yes good, no bad. Toss the kevlar spirals in the drawer.
  3. #93
    Feb 2020
    MinneSnowda
    Jul 2005
    AZ
    You can go online and order everything and make your own plug wires... excatly as long/short as you want.. for me it was alot cheaper and have enough for a second set of wires
    '84 Checkmate Convincor
  5. #95
    Sep 2008
    charlestown, ri
    Hey you could always buy my GT150 heads all cleaned up and ready to rock. will definitely give you more compression to make use of those 64's!
  6. #96
    Quote Originally Posted by DieselDood View Post
    91-06 60° inductive ?
  7. #97
    Feb 2020
    MinneSnowda
    Crap I missed that. Good thing I didn't hit the Order Now button! LOL
  8. #98
    Feb 2020
    MinneSnowda
    Quote Originally Posted by Revenge22 View Post
    What are you looking to get for those? Feel free to PM if you'd like
  9. #99
    Can't recall the 150GT psi. Are they higher ported than 150/175?
    https://www.screamandfly.com/showthr...ghlight=150GT&
  10. #100
    Sep 2008
    charlestown, ri
    i'm assuming the gt's did have higher and wider ports, but ask Racer he knows more. I think the gt150's had about 15-20 psi more. so around 120psi instead of 95-100
  11. #101
    Feb 2020
    MinneSnowda
    Good read FMP. It looks like the heads that Revenge has, and the 1 3/8 carbs I already have may not be a bad combination.
    I keep reading about intake stuffers, and I've seen little pictures of the rubber chunks, but I can't seem to figure out where they go.
    At this point... If I'm doing heads and big carbs, I may as well go all out and do the bubble back and find/install the stuffers too.... LOL
  12. #102
    If you advance search 150GT a few good threads pop up.
    They compare the S block of the previous years GT to similar as the 175.
    I think the psi should be around 120 but that's still lame unless it's a barge workhorse IMO. Also total ign advance was detailed over 30°, that helps xflows like it.
    Also read the head numbers somewhere
  13. Likes mrichartz liked this post
  14. #103
    Jul 2005
    AZ
    Intake stuffers ..they are installed between reed block and int Where the gasket is once you see them you'll know..
  15. #104
    Feb 2020
    MinneSnowda
    I've read that, but it just doesn't quite make sense to me. They go in the valley between the reed?
  16. #105
    Jul 2005
    AZ
    They are/look just like the gasket just thicker.. so when you see it it makes sense it's a (spacer) mounts reed farther in reducing space(your trying to decrease the amount of space in there). if that makes sense..
    You can also do things like get plastic dowels and plug the case bolt holes inside.
    Chris Carson has the spacers reeds etc. .. if I didn't have mine milled would have used them
  1. ISO crossflow jets
    By bruzercomp81 in forum Parts Wanted
    Last Post: 02-19-2015, 08:35 AM
  2. marine tech needs some auto tech help
    By fkboatman in forum Technical Discussion
    Last Post: 10-24-2008, 10:02 AM
  3. Yamaha jets vs. Bombardier jets
    By wmsthree in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 07-31-2008, 07:52 PM
  4. Crossflow intermediate and High speed jets
    By Lockjaw in forum Technical Discussion
    Last Post: 12-31-2005, 05:24 PM
  5. Crossflow jets
    Last Post: 12-12-2005, 06:45 PM
