Results 1 to 9 of 9
    Daytona Fl.
    5 Post(s)
    Five blade Hill cleavers for the new V8 motors
    These are the props to have on the new V8's. Pitches available are 26" - 38". 15.25" diameter is what is needed to hook up. They run only 4% slip on all my Liberators and on a Bullet bass boat we tried. 9 mph faster than the same size Mercury Max 5 and the EXACT same speed as a $5500 Mercury CNC 5 blade cleaver. I sell these for $2150 to your dooror $4300 for a pair. One year warrantee and you can swap out for a different pitch within 30 days at NO CHARGE. Nobody does that! Email Liberatorboats@yahoo.com or call 386-295-2132
    Boat Delivery available
    Things owned. NOTHING!!
    Jul 2010
    Moss Bluff Louisiana
    Randy , You said in a previous post that the cleaver was fastest with a lighter load. Lets say you had loaded your 22ft down, and it weighed 3100 lbs on the water, any idea how it would run with the cleaver then ?
    Daytona Fl.
    5 Post(s)
    Surfacing it will be the fastest. The only negative with any cleaver, 3-4 or 5 blade, is they slip more getting on plane unless you have a hyd plate to lower it for more bite. I usually sell customers two props. One for top end and a different one for a loaded boat
    Sep 2012
    Would this prop work with a 21 skater and a 300x? If yes, what pitch?
    Daytona Fl.
    5 Post(s)
    I am not sure. I was told the for blade cleavers work pretty well. I am supposed to get some this week to try. They are 995 each
    Jul 2010
    Quote Originally Posted by WILDMAN View Post
    Two props makes sense , just was trying to decide if the cleaver would still be fast on same boat loaded much heavier, I used 3100 lbs , because I estimate that is where Iím at . I didnít know if you had ever tested with much heavier loads .
    Daytona Fl.
    5 Post(s)
    The Liberators weigh about 1900-2000 lbs fully rigged with motor. Probably need more of a bow lifting prop if you have a heavy load
    Jun 2002
    Waterford, CT
    I have owned my 32 Skater for 18 years.
    Yes I have tried a few props........ lol
    These are by far the best performing props with my 300R motors.
    The statement about 30 day exchange is 100% true!
    I did it.
    Feb 2003
    Any thoughts as to performance on a 21 Allison bass boat and a 250R ?
    It really likes the max 5 but I do run heavy.. yes I have hydraulic j-plate
  1. Replies: 17
    Last Post: 10-21-2019, 12:31 AM
  2. Replies: 0
    Last Post: 08-21-2017, 07:15 PM
  3. Ron Hill 26 4 blade. Trade for 28 4 blade
    By crusader83 in forum Propellers
    Last Post: 07-28-2017, 12:58 PM
  4. Replies: 17
    Last Post: 01-30-2016, 12:35 AM
  5. Ron hill signature eagle et 4 blade or 5 blade
    By frontline in forum General Boating Discussion
    Last Post: 08-27-2014, 06:42 PM
