Results 1 to 3 of 3
Thread: 89 Skeeter SK1700 Porposing
04-30-2020, 08:53 PM #15000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 102
- 28
I've got an 89 Skeeter SK1700. (17'10" bass boat)
Last season I ran an 85hp motor that really wasn't enough for it. It struggled to get on plane, but once it did, I could get 30 out of it and it was smooth as could be.
Last fall I picked up a 150hp motor and an 8" jack plate. (and hydraulic steering)
I just got the motor running properly, and set the motor to 3.5" below pad. I took it out and it really struggled with a 21P prop to get on plane. I would have to actually turn left for about half a circle to get enough RPM to get it to get up on plane. Once it nosed over, if I'm in a or out of the throttle or just trying to cruise at say 30ish it Porposes badly. While messing with it I was trimmed all the way up, and was working on trimming down when I gave it some throttle and I literally had everything but the motor out of the water. It was VIOLENT.
I pulled it out of the water and raised the jack plate an inch and it improved both the holeshot and the porposing. Looking at where it is set now, I don't know if I dare go much higher at this point.
I have a water pressure gauge I'm working on installing, but it's not in yet.
How high can I safely go? Will going higher help? Or is it a leverage thing and the jack plate is actually causing my issues? The 85hp was smooth, I'm really surprised at how badly things were with the 150.
Once I was past the Porposing, it would run 51mph at both Pad to prop depths I ran.
Honestly I was hoping it would spin a 23P. As it sits right now... If I put another person in the boat and a livewell full of fish, I'm not going to get on plane.
Any advise would be welcomed! Thanks
05-07-2020, 04:51 AM #2
What prop is it ?
05-07-2020, 09:17 AM #35000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 102
- 28
When I wrote this post and was out I had a 21P aluminum on it. Right now I have a 23P Ballistic on it, but I've found some motor running issues that I'm trying to track down.
I had it up on plane with the Ballistic, but it was rough water once I got out of the bay I was in... and I found the case halves leaking. I resealed them and now it actually runs worse..... I think I shook some gunk loose in the carbs. So I'm going to pull them down and verify the jet sizes. It's running VERY rich, with white smoke.
Plus side... I found it has .040 Wiesco Pistons and Boysen reeds in it. So I guess splitting the case wasn't really a "bad" thing.
I'll update this post after I get it running properly and on the water again. I also will be picking up a 24P Raker from a buddy and I scored a 25.5 reworked Raker off FB Marketplace. Man I love when People don't know what they have... that 25.5 was $50!
Porposing
By TerrySVT in forum General Boating DiscussionReplies: 4Last Post: 09-24-2012, 09:48 PM -
Porposing
By ironlake2 in forum Outboard and Racing HistoryReplies: 10Last Post: 09-10-2009, 01:18 PM -
Porposing problem
By fugley01 in forum General Boating DiscussionReplies: 3Last Post: 10-05-2006, 04:26 PM -
Porposing problems...
By JSB5776 in forum General Boating DiscussionReplies: 1Last Post: 06-28-2002, 12:31 PM -
Porposing
By roxin in forum Technical DiscussionReplies: 2Last Post: 04-06-2002, 01:33 PM
