Results 61 to 75 of 76
05-15-2020, 12:24 PM #61Member
- Jan 2014
- Pataskala, OH
- 71
Well the good news is I have great charging voltage now. Bad news is my RPMs read about half what they should. Usually around 50mph I see 4000 - 4200 if I recall. I was getting around 2000 with the new rectifiers/regulators. I may need to pull the gauge and see if there are switches on the back I can tweak.
05-15-2020, 03:15 PM #62
Back of guage Should b a switch/ dial swapping from 3,4 6 etc , twist it back and forth dozen times or so to try clean little contacts inside of it.
05-20-2020, 02:11 PM #63
05-20-2020, 09:09 PM #64
90 5.0 liked this post
06-22-2020, 11:52 AM #65Member
- Jan 2014
- Pataskala, OH
- 71
06-22-2020, 05:58 PM #66
Damn, bud, that sucks!!!!!!!! Glad you were ok. Which ones were those?
06-22-2020, 09:54 PM #67Member
- Jan 2014
- Pataskala, OH
- 71
Those are: https://www.ebay.com/itm/New-Voltage...53.m2749.l2649
I ordered 2 more of these: https://www.ebay.com/itm/NEW-VOLTAGE...53.m2749.l2649
$50 more for the set, but fingers crossed that being more expensive will mean a little better quality.
06-12-2022, 10:59 AM #68Member
- Aug 2020
- Dallas
- 58
- 22
- 11
Did those new ones solve your issue?
06-12-2022, 10:30 PM #69
06-13-2022, 05:15 AM #70Member
- Aug 2020
- Dallas
- 58
- 22
- 11
My water cooled rectifier just went out on my XR4. I think my system is the 40v because of the red flywheel and this style rectifier. I just need to figure out some part numbers for the 5 wire trigger to replace my 2 wire, and then a couple rectifiers/regulators.
06-14-2022, 11:49 PM #71
If you don’t really need the 40 amps, put on a 16 amp flywheel and stator and one rec/reg
06-15-2022, 08:49 AM #72
06-15-2022, 10:06 AM #73
Roy,
That's what I did, too. Most of my festivities are well over 3K rpm so the 16A has been just fine for my purposes1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
06-15-2022, 10:52 AM #74Member
- Aug 2020
- Dallas
- 58
- 22
- 11
Ok I’m going to do that. I’m having trouble locating a 16 amp flywheel. Do either of you guys have a part number for that, or know where to get one that isn’t $500? Same goes for the 16 amp stator. I think I’m showing the part number for that one as 174-5456-16.
06-15-2022, 01:54 PM #75
You might look into these. You use one of these for the 40-amp system... and no water-cooled bull****. I had to buy a special crimper...Aircraft Tool Supply #E300-005
https://rmstator.com/en_ww/rm30504h
http://roadstercycle.com/
Connectors for motor side, first set: http://www.easternbeaver.com/Main/El...onnectors.html
rectifier? regulator?
By jmr112 in forum Technical DiscussionReplies: 2Last Post: 10-13-2003, 10:52 PM -
Merc Regulator and Rectifier Wiring Schematic
By Matt in forum Technical DiscussionReplies: 1Last Post: 08-17-2001, 07:01 AM -
3 cylinder Merc 75-Rectifier/Voltage Regulator
By WillyT in forum Technical DiscussionReplies: 1Last Post: 07-12-2001, 06:28 PM
