Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
  1. #31
    Mar 2009
    Hot Springs, AR
    Update! I've sanded, compounded, and polished but I think the black gel is too oxidized. At first it looks amazing but after a few days, I start getting microscopic white dots which I can only believe is pitting in the gel itself. It looks 100% better than it did but I cant keep it black black like I hoped. I can live with it for now but I think paint or clear is my only option
    92 Mirage Ski Racer
    86 Laser LTV Bass
    82 Hydrostream Vandal Comp
    ^(project that needs a new home)
  2. #32
    Jun 2018
    Floating around
    Cant you spray clear gel over and polish that up?
  3. #33
    May 2016
    keys
    Black wax?
  4. #34
    Jul 2019
    Tennessee
    I tried to explain that but was shot down by those who have sanded and polished for countless hours. If you sand that down a just shoot a cote of high quality automotive clear on it, it will last for years if you prep it correctly, this will probably take less time than it did to get to where you are at now. If and when you do the gel coat job, removing that clear will be easy.
  5. #35
    Carrollton, Tx
    Quote Originally Posted by dtmeeks View Post
    The polish has fillers that hide the true appearance, in a few days/weeks the real surface oxidation shows back up. Use a compound that doesn't have them and wipe it down with Windex to see what you're really left with. You should spend twice as long to buff out 1000 with 1500 in an area. Just to get the 1000 scratches out.
    https://www.youtube.com/watch?v=sE8rx20tk2M
    Robert Jackson
    1991 Voyager XT 250 HPDI
  6. #36
    Jun 2018
    Floating around
    I meant gel coat thats clear. Why not spray that over and polish? The auto clear works but ehhh chips and scratches and looks kinda bad quick. Its not cheap either and if it is cheap product its not worth using imo.
  1. base coat clear coat WITH PEARL chameleon added
    By roadkill636 in forum Appearance Mods
    Last Post: 12-23-2015, 04:41 PM
  2. Any advice for stripping clear coat off gelcoat?
    By gregpro50 in forum Fiberglass and Composites Discussion
    Last Post: 04-20-2010, 06:28 PM
  3. Clear coat advice needed on alumanum boat
    By roadkill636 in forum Technical Discussion
    Last Post: 04-23-2009, 01:18 PM
  4. Advice on repairing Gel Coat Hull Damage
    By SRP71 in forum Fiberglass and Composites Discussion
    Last Post: 03-12-2005, 11:36 PM
  5. Gel Coat Expert Needed
    By mikiedreb in forum Fiberglass and Composites Discussion
    Last Post: 07-15-2004, 03:28 PM
