Results 1 to 12 of 12
04-23-2020, 04:22 PM #16000 RPM
- Loudon Tn
- 1,430
- 7
- 59
new fuel sending unit working backwards?? Little help please
On my Allison the fuel sending unit stopped working. It had three wires coming out of sending unit. Got a new sending unit (this one only had two wires)?? Installed and it works except it reads full when tank is empty. Any thoughts. Thanks in advance for any input guys.
Stay healthy have fun
04-23-2020, 05:25 PM #2
you need a hot wire to gauge 12+volts.. then need 12+volts at sending unit and a ground at gauge and ground at gauge must go to the sending unit... the center of sending unit Is the 12+volt and the outside one is the ground
1979 hydrostream vector sold
2001 american offshore 26 twin 300 promaxs
2006 hydrostream comp vking horned 225 promax/
1986 23ft twin engine eliminator twin 225 promaxs SOLD
04-23-2020, 07:09 PM #35000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
did you try reversing the two wires
04-23-2020, 10:41 PM #4
You prob have a european sender or gage they use opposite values for full empty, us is 240 ohms empty and 33 full... 3 wire would have been a capactance type
04-23-2020, 11:20 PM #5Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
Just turn the gauge upside down.
gfinch thanked for this postInjectorService, gfinch liked this post
04-25-2020, 10:19 AM #6
04-25-2020, 10:35 AM #7
Turn boat upside down.
Azure AZ259, 8.1
04-25-2020, 02:22 PM #8
There are capacitance type 3 wire units that use 12v at the sender...they are tube type without a float, the tube type with a float normally only have 2 wires and dont typically ground to the tank like the old school wiper resistor ones...
04-25-2020, 03:37 PM #95000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
Any analog gauge driven by a DC millivolt or milliamp signal will be driven "upscale " with current flow in one direction and "down scale " with the current flow reversed . The Polarity will determine which direction the pointer moves and magnitude of the signal will move the pointer travel from zero thru full scale .
A capacitive type device is going to convert the liquid level into a corresponding mv or ma signal to drive the meter . The simplest solution would be to find out from the fuel gauge manufacturer which sending unit(s) and wiring configuration to use with their gauge . It's only 2 or 3 wires how hard can it be?
04-25-2020, 04:15 PM #10
No ones arging how simple or hard it is just there are 1/2 and 3 wire senders and 2 different ohm to fuel level standards for marine gages depending on the which side of the pond you live on... so there are variables.
04-25-2020, 04:27 PM #115000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
That's why I suggested talking to the manufacturer of the fuel gauge to find out type of sender(s) were compatible . They will have the answer right now .
04-25-2020, 04:44 PM #12The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
I like to stick with the old fashion swing arm senders. the centroid electronic senders require a hot wire to the sender. no thanks on a rough water boat. have "lots" of experience with the centroids.
XstreamVking liked this post
Whats the best fuel tank sending unit?
By capteliminator in forum Technical DiscussionReplies: 11Last Post: 03-25-2013, 06:41 AM -
Who has the best fuel Sending unit
By RLC PE in forum General Boating DiscussionReplies: 9Last Post: 11-10-2008, 09:29 PM -
Fuel Sending Unit Float
By VectorPat in forum Technical DiscussionReplies: 4Last Post: 06-19-2003, 05:56 PM
