Results 1 to 6 of 6
Thread: EFI 225 promax quickleen
04-23-2020, 01:58 PM #1Member
- Feb 2019
- Midwest
- 82
Have any of you guys used quickleen in 225 promax? I'm not having any injector issues but the engine is 22 years old and I've never had the injectors cleaned. I've always ran BP premium fuel with seafoam and klotz. I also wondered if it would get rid of carbon build up on the piston?
04-23-2020, 02:09 PM #26000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Your basically running cleaner through all the time so I doubt it would change anything. Unless your doing the vst quickleen treatment.
chunks of carbon on the piston yes. But theirs always a fresh layer of carbon on the piston.
04-23-2020, 03:59 PM #3
Its a bandaid fix at best. You might clean a bit of varnish out, but your not cleaning the filters, and not really diagnosing the injector at all. It's a feel good thing. Drop some in, you feel good, but as far as TRULY cleaning them, you need to send them out.
www.InjectorService.com
Call/Text - 204-326-0390
04-24-2020, 10:58 AM #4
I use it all the time on my Pro Max.
InjectorService liked this post
04-24-2020, 01:15 PM #5
sea foam/klotz 22 yrs?.. ain't broke why "fix" it???.. i'd be more worried 'bout 'em being plum wore out!
simpson_3 liked this post
04-24-2020, 02:41 PM #6
Mercury Tech: Quickleen in a 280
By BagMan in forum Technical DiscussionReplies: 13Last Post: 10-29-2009, 08:05 PM -
Quicksiler Quickleen
By 2Blade in forum Technical DiscussionReplies: 1Last Post: 03-27-2004, 07:17 PM -
Quickleen
By gaineso in forum Technical DiscussionReplies: 5Last Post: 05-10-2003, 06:00 AM -
Do I need to use Quickleen?
By gw204 in forum Technical DiscussionReplies: 1Last Post: 05-07-2003, 04:37 PM -
Quickleen
By bucket in forum Technical DiscussionReplies: 2Last Post: 10-03-2002, 05:29 PM
