Results 31 to 42 of 42
05-08-2020, 09:40 PM #31
Ya I wasnt think ecu anyway. Without reading thru again , what all have changed or tested
05-08-2020, 10:29 PM #32
If you have not done a leak down ,its time and should of been done first ,compression means nothing except what fuel to use ,i have had many motors with good even compression numbers and fail leak down ,last one had broken rings on 2 cylinders and would not run on the 2 cylinders with broken rings it was a 1995 evinrude 115 ,your rings and cylinder’s could be toast
05-08-2020, 10:56 PM #33
Looked at reeds yet?
05-09-2020, 07:56 AM #34Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
05-09-2020, 08:07 AM #355000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
reeds are good, new cdm's, new triggers, new plugs, have swapped ecu and swapped injectors around and it still doesnt run on 2 and 4.
i havent done leak down yet
05-09-2020, 08:12 AM #36Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Swap cdm , or "custom tuned" plug wires on 2,4
05-20-2020, 08:06 AM #375000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
swapped cdm from 2 and 4 and still the same
05-20-2020, 11:06 AM #386000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Are you sure it’s missing. Some of the mercs can run smoothly like a v4 or or such
check all the plugs are on the right parts like before the electrical is the plug to the cdm is swapped between 2-4 it will fire and look good all day. Same with injection plugs. But never run.
05-20-2020, 12:04 PM #395000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
you can take plug wires off 2 and 4 while running and it makes no change in sound or rpm
06-04-2020, 05:11 PM #405000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
Still can’t figure out the problem with cylinder 2 and 4.
when first started after setting a day it idles great on all 6 cylinders for about 30 to 45 seconds then drops cylinders 2 and 4
06-04-2020, 05:21 PM #41
Dont no enuff bout cdm stuff to help , but if u got good compression /leak down , then its fixable , maybe u should do leak down. Without reading thru again. U say its firing all 6 when u check ?spark
06-22-2020, 10:36 AM #425000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
it has spark on all 6 cylinders
when first started it runs on all 6 cylinders for less then a minute then drops 2 and 4
2 and 4 still have fire but wont run on those 2 cylinders
2000 200efi wont turn over 5500rpm any size prop
By BigKiddd in forum Technical DiscussionReplies: 2Last Post: 09-02-2017, 02:57 PM -
Mercury Tech: 1990 XR4 wont spin past 2000 rpms????
By gordie in forum Technical DiscussionReplies: 5Last Post: 07-06-2017, 02:51 PM -
Mercury Tech: 3.0 250 merc wont rev up past 2000 r.p.m timing goes haywire
By SCOOBARON in forum Technical DiscussionReplies: 4Last Post: 03-31-2012, 01:29 AM -
2000 Yamaha 2 stroke 250 wont start!
By Dilligas in forum Technical DiscussionReplies: 8Last Post: 07-28-2006, 03:33 PM
