Results 16 to 30 of 42
04-23-2020, 03:44 PM #16
I'm no efi kinda guy. But if u got fire and compression. U only got 1 thing left to not fire a cyl. U got ecu driver issue or harness issue. U need test light, volt meter sumthin to check and c if that injector is gettin its signal. Lots very experienced guys with this , u need b figurin out if those injectors firin. Swappin injectors wont do it. Cause if the pig tail ain't hot it won't t do any good
04-24-2020, 11:48 AM #175000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
all 6 injectors spray while i was cranking engine.
i had the injectors out so i could see then and cranked engine and all 6 spray.
i am baffled on why 2 and 4 make no difference when take plug wires off
04-24-2020, 03:07 PM #18
Fuel ,fire,compression is good. Well just keep digging. I'm sure u will find it. I'd double check the bores if possible
04-25-2020, 10:32 AM #195000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
now i have no spark on cylinder 2 but have spark on 4 but still doesnt run on 2 and 4
04-25-2020, 01:12 PM #206000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Does it have a shift interupt that will kill one side if it has one. Sometimes it’s only a neutral start if anything on some mercs others have it in the remote.
are you sure the fuel is good. Non That would affect all of them.
Have you check the ohms on the plugs. They can be busted
04-27-2020, 12:36 PM #215000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
fuel is good.
plugs are good.
new triggers and all new cdm modules
04-27-2020, 02:21 PM #225000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
if the box behind flywheel is bad will it kill fire to number 2 cylinder?
the triggers plug into it then wiring comes out of it to cdm harness
04-27-2020, 03:51 PM #23
Yes #2 is the first cylinder to be dropped by the rev limiter and sequentially goes around the cylinders the deeper you get into the limiter
04-28-2020, 01:00 AM #24
i vote "control module".......................
04-30-2020, 01:50 PM #255000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
new control module and still wont run on 2 and 4
have very good spark on all 6 cylinders now
04-30-2020, 03:40 PM #26
04-30-2020, 03:50 PM #275000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
i am at a loss.
dont know what else it could be
04-30-2020, 04:04 PM #28
at this point ona computer last resort for me.. run it at night with cowl off.. take a well insulated screwdriver and start with tha plug wires and every wire associated with those two cylinders and see if got got any "leakage" anywhere
FMP liked this post
04-30-2020, 05:00 PM #29
Find a old 2.0 or 2.4 a d replace everything electrical.
Edit. Should had said and swap over to ALL the 16 amp stuff and try it.
05-08-2020, 08:37 AM #305000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
i have swapped ecu and still no change
2000 200efi wont turn over 5500rpm any size prop
By BigKiddd in forum Technical DiscussionReplies: 2Last Post: 09-02-2017, 02:57 PM -
Mercury Tech: 1990 XR4 wont spin past 2000 rpms????
By gordie in forum Technical DiscussionReplies: 5Last Post: 07-06-2017, 02:51 PM -
Mercury Tech: 3.0 250 merc wont rev up past 2000 r.p.m timing goes haywire
By SCOOBARON in forum Technical DiscussionReplies: 4Last Post: 03-31-2012, 01:29 AM -
2000 Yamaha 2 stroke 250 wont start!
By Dilligas in forum Technical DiscussionReplies: 8Last Post: 07-28-2006, 03:33 PM
