Results 1 to 15 of 42
04-22-2020, 10:51 AM #15000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
2000 mercury 150 efi xr6 wont run on cylinders 2 and 4
i have replaced all cdms and new triggers
i have swapped ecu with another and still same problem.
i even swapped injectors to different positions with no change.
i have spark on all 6 cylinders
04-22-2020, 11:18 AM #2
You still running oil injection? Compression and leak down numbers?
04-22-2020, 11:38 AM #35000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
yes still running oil injection.
105 to 110 on all 6 cylinders
04-22-2020, 11:40 AM #45000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
wondering if the controller can be the problem.
the one on top of motor behind flywheel.
the triggers go to it then out of it to the cdm modules
04-22-2020, 01:11 PM #56000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Would almost say time maybe. But you have new cdm on. Have you swapped them.
after that you in the harness or have busted reads and got compression from sucking in through the exhaust.
literly baffles the mind with compression spark and fuel.
04-22-2020, 01:23 PM #65000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
reeds are good.
have heard the controller box controls injector timing.
i just dont know what else to try.
was exactly the same cylinders before we replaced all cdm modules and triggers
04-22-2020, 02:15 PM #75000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
can anyone help me with what else i can try to get this figured out?
i unhooked shift switch and heat sensor and no difference.
i have switched stator wires around also and no differenceLast edited by zookimota; 04-22-2020 at 03:43 PM.
04-22-2020, 08:04 PM #8
A 555 motor I'd look for a running voltage issue after that the ECU will be need to be sent in and checked for faulty drivers.
04-23-2020, 08:40 AM #95000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
where do i check running voltage at?
04-23-2020, 12:00 PM #10
Alternator. Sounds like you lost a couple injector drivers I would check that route first.
04-23-2020, 12:47 PM #115000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
14 volts out of each voltage regulator
04-23-2020, 02:18 PM #126000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Can’t remember if it possible but check the injectors are plugged in the correct plug. (Like crosswired sparkplugs)
you can pull one and spray in a bottle to check functionality. Or pull the spark plug and smell for gas in the cylinder. Both are a little spooky but doable.
are you positive it’s only 2 and 4
04-23-2020, 02:22 PM #13
Dont the driver in ECU run 2 injectors at a time? In other words 3 drivers 6 injectors? Capt said it earlier. Need see if u got power to those injectors or see em sprayin
04-23-2020, 02:31 PM #145000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
i had the injectors out and switched to different cylinders but still wont run on 2 and 4.
if you unhook cdm or take plug wire off on each cylinder it makes a difference except on 2 and 4
04-23-2020, 02:34 PM #155000 RPM
- Jan 2003
- Cordell, Oklahoma
- 179
how can i check to see if they spray when they are in a manifold in front of engine behind the ecu?
2000 200efi wont turn over 5500rpm any size prop
By BigKiddd in forum Technical DiscussionReplies: 2Last Post: 09-02-2017, 02:57 PM -
Mercury Tech: 1990 XR4 wont spin past 2000 rpms????
By gordie in forum Technical DiscussionReplies: 5Last Post: 07-06-2017, 02:51 PM -
Mercury Tech: 3.0 250 merc wont rev up past 2000 r.p.m timing goes haywire
By SCOOBARON in forum Technical DiscussionReplies: 4Last Post: 03-31-2012, 01:29 AM -
2000 Yamaha 2 stroke 250 wont start!
By Dilligas in forum Technical DiscussionReplies: 8Last Post: 07-28-2006, 03:33 PM
