Results 1 to 2 of 2
04-21-2020, 03:31 PM #1Member
- Jul 2005
- 37
Hydrostream Vamp or Verado Transom Construction
Anybody familiar with Vamp or Verado Transom design/construction? I'm rebuilding the cracked and slightly rotted transom on a 1982 Hdrostream Vamp (bowider version of the Verado). That hull has a flat transom across the center, with winglike, foamfilled "pillows" extending out to the sides, which angle back at about a 15 degree angle, rather than forward as on most other Streams. I've removed all of the wood from the center section from above. The wood appears to go about an inch out toward the side past where the pillows begin, and after that it's all foam. There seems to be no wood in or behind the pillows. So the wood transom appears not be tied in at all to the sides of the hull. I'm wondering what supports the transom if that's the case. Or am I missing a something that's obscured by the foam. I don't want to cut into the transom fiberglass to explore unless I have to.
04-21-2020, 08:25 PM #2
I can't speak for that particular hull. But I can tell you there's nothing but the glass holding the transom in a Viking/Vking. It just kinda hangs back there. No other structure contacts it. Thats why knees/gussets are so important when rebuilding.
So I wouldn't be surprised if they did it the same on this hull.'78 Hydrostream Viking/'98 225 ProMax
hydrostream vamp project
By 1954bmw in forum General Boating DiscussionReplies: 13Last Post: 03-17-2020, 08:04 AM -
17' Hydrostream Vamp transom repair
By buckybro in forum Technical DiscussionReplies: 2Last Post: 06-22-2017, 09:50 AM -
Allison transom construction
By Matt Gent in forum General Boating DiscussionReplies: 0Last Post: 03-19-2016, 07:56 PM -
Hydrostream Vamp
By Diz in forum General Boating DiscussionReplies: 2Last Post: 04-09-2013, 07:26 PM -
Hydrostream Vamp Setup
By tbay_vamp in forum Props, Setup, and RiggingReplies: 7Last Post: 08-30-2006, 08:21 AM
