Results 106 to 120 of 145
Thread: 1983 shadow 21' build up
04-28-2021, 08:44 AM #1065000 RPM
- Dec 2019
- Lake villa Illinois
- 116
- 14
- 135
Seats are in
04-28-2021, 11:17 AM #1075000 RPM
- Dec 2019
- 116
- 14
- 135
Bench is almost done
04-28-2021, 07:18 PM #1085000 RPM
- Dec 2019
- 116
- 14
- 135
Cleats are mounted and ready. Went with a 6” accon pop up. So this is the 3rd cleat I’ve had in this boat. As you can see I’m very indecisive 🤡😅. Also having a full cover made. Hopefully get the floor done soon and fire it up after I bleed the steering.
tnelsmn liked this post
05-01-2021, 04:27 PM #1095000 RPM
- Dec 2019
- 116
- 14
- 135
Bench is done. Sanded floor back down to primer and reprimed and spray a single reduced layer of raptor liner. I like the durability of it over Gelcoat. I only sprayed 4mils worth of coating roughly. Figured it would be even easier to sand off than a thick layer of gel if a repair was ever needed. I only prayed around where seadek willl be going, rest of floor and bulkheads and bilge remain white.
05-01-2021, 06:07 PM #110
How far of a reach is that paddle switch attached to the helm with your set up? I ran into that myself using a seastar helm. You need to take your hand off the wheel to reach it, Those are made for their own Uflex helm where they mount up closer to wheel. I am making a spacer to move it out.
05-01-2021, 11:00 PM #1115000 RPM
- Dec 2019
- 116
- 14
- 135
2.5-21 liked this post
05-03-2021, 10:49 PM #1125000 RPM
- Dec 2019
- 116
- 14
- 135
Comin along
05-17-2021, 11:38 AM #1135000 RPM
- Dec 2019
- 116
- 14
- 135
The original panels cracked when I dropped one. It was a bad design, the the pvc board I made too narrow of a piece by the cubby/speaker. That left it very weak. So I redesigned and built new panels. Just finished covering them.
tnelsmn, Velocity72 liked this post
05-17-2021, 11:59 AM #1146000 RPM
- May 2001
- Madison, WI
- 1,147
- 253
- 39
- 499
- 198
Do you know how heavy did that panel turn out using the PVC board?
Looks great and won't rot
05-19-2021, 10:13 AM #1155000 RPM
- Dec 2019
- 116
- 14
- 135
05-19-2021, 05:28 PM #1165000 RPM
- Dec 2019
- 116
- 14
- 135
Comin along
05-22-2021, 01:34 AM #1175000 RPM
- Dec 2019
- 116
- 14
- 135
Panels are in and shifter mounted. Just need to trim seat brackets.almost there !
05-22-2021, 05:39 PM #1185000 RPM
- Dec 2019
- 116
- 14
- 135
Just waiting on power purge for steering abs gas fill hose
05-22-2021, 05:40 PM #119Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
You have been rolling big time. Looks great!
Pepperson4 liked this post
06-03-2021, 12:27 PM #1205000 RPM
- Dec 2019
- 116
- 14
- 135
Got the foot throttle mounted and steering bled finally. Motor fired right up as expected. Just need prop hub and I’ll drop her in
