Page 6 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 76 to 90 of 145
  1. #76
    Dec 2019
    Lake villa Illinois
    Your supposed to change your dash core every 6 months right? Haha was feeling ambitious and I hate how high the steering wheel was and the dash size. So I chiseled out all the core by hand and am recor-ing it to how I want it. Wish I would just leave stuff alone sometimes 😂
    Attached Thumbnails Attached Thumbnails 0F1971CE-6BA5-4B74-8016-E8674E19C5F1.jpg   AE42D4CE-B764-4759-89EF-9392DD55A9D8.jpg
  2. Likes tnelsmn liked this post
  3. #77
    Dec 2019
    Lake villa Illinois
    Core is cut out and in. Using all epoxy resin. Was able to trace the rear skin as my template. Using 3/4 “ ply. Tapered all my edges inside and out for the new skins. Used epoxy thickened with cabosil to bond core on. Used clamps where I could snd existing holes I used screws. Was able to get a good squeeze as you can see from all the excess epoxy everywhere. Filled any gaps with thickened epoxy. Bottom of dash (back side) has a radius sanded in to it. I will use 1708 for front skin first and overhang it by 1/2” past the wood. That will give me an area to add a fillet for a smooth transition from the rear skin onto the front skin. Also a nice lip for edge trim to attach to.
    Attached Thumbnails Attached Thumbnails 531D16B4-1670-4CCC-8C6B-1E407EF6F330.jpg
  4. Likes Greg G, tnelsmn liked this post
  5. #78
    Dec 2019
    Lake villa Illinois
    Front skin made. 3 layers of 1708. CSM first, 1708, csm, 1708, and then two final layers of 1708 to top it off for the desired thickness. Fillet created in back for skin to transition to hull. Will be two layers of 1708 on back skin. Obviously will be trimmed off flush on bottom, it’s overhanging by about an inch currently.
    Attached Thumbnails Attached Thumbnails 7D5ED8B0-DD14-466C-86EC-408584C3C415.jpg
  6. Likes tnelsmn liked this post
  7. #79
    Dec 2019
    Lake villa Illinois
    Well finally got the rear skin on, 2 layers of 1708 after I faired in the core. Will get a white coating of macropoxy same as floor. Got the front mudded also. Still need to do final trim on bottom, about 1.5” will be coming off . Using total fair epoxy fairing compound. Works amazing. Very thick tho so takes some effort to spread compared to bondo. But we all know bondo doesn’t belong on boats! The whole dash will be painted black
    Attached Thumbnails Attached Thumbnails 172F8FB6-F9B3-4CE2-8BAB-F4596D0CA12E.jpg   46532E87-1A8B-4E53-9665-6D3751D06598.jpg
  8. Likes tnelsmn liked this post
  9. #80
    Minneapolis MN
    That will be a nice blank canvas to start with for the dash.
  10. Likes Pepperson4 liked this post
  11. #81
    Dec 2019
    Lake villa Illinois
    Got the bottom trimmed off today. Was happy with the overall thickness of about 1/4” on the bottom lip. Worked out good for a surface to attach a trim piece too. Got the first layer of filler blocked down and did a skim coat before I left. Will likely need another skim coat once I use a guide coat to really get it flat. Helps to have a nice set of blocks as well.
    Attached Thumbnails Attached Thumbnails C381CDEA-B49D-4854-AB30-97F0891EE1D2.jpg   8D22B4A7-23E1-49A7-A56B-5E880DCCC9BE.jpg   65060C73-3491-4DDD-8933-350B1BCFA42E.jpg   B56A2AD7-24DA-41DD-9BFC-E12C764FE8F8.jpg
  12. Likes Greg G, scott reierson, tnelsmn liked this post
  13. #82
    Dec 2019
    Lake villa Illinois
    All done. Just kidding got the guide coat on and sanded off. Got it pretty damn straight. Did a final skim coat on a couple low spots I missed. Hopefully get primer on Tomorow. Then will do a sealer most likely
    Attached Thumbnails Attached Thumbnails 512DD61C-B030-4D30-9D1C-52D7CF2508FA.jpg   05C6B2A1-C9C0-49ED-910C-8D3F5B49ED91.jpg
  14. Likes tnelsmn liked this post
  15. #83
    Nov 2020
    New Zealand
    Good work
    Did you enjoy overhead glassing the back of the Dash?
    Did you have resin run down your arms and that blinding stinging feeling in your eyes and forehead or am I just an amateur?
  16. #84
    Dec 2019
    Lake villa Illinois
    Quote Originally Posted by NZ Sidewinder View Post
    Good work
    Haha yea I had that happen when I was wetting it out to put the core on. Learned my lesson and got a full tyvek suit on and glasses. Also I prewet out all the laminate in the ground first, made it way easier. Helps a lot with epoxy since it’s tougher to get it to wet out than vinylester or poly
  17. #85
    Dec 2019
    Lake villa Illinois
    Refitting the side panels tonight to the new dash. Will be spraying some 2k primer on soon. Then a sealer and then paint. Got my new seats in as well. Really like what the nitra guys are doing so went with the same seats. Very high quality and comfortable. Went with alloy side brackets for them as well.
    Attached Thumbnails Attached Thumbnails D767E1C4-2F53-426E-8750-25266F7A766F.jpg   3EF7362D-EA77-48F1-8796-F523133B0CD3.jpg   F5B76C74-3AD5-42F5-A51B-2BA49E9B1195.jpg   77F2B4E3-B641-4F9E-8A5A-7E5F1A81673E.jpg
  18. #86
    Jul 2004
    Connecticut
    Looking good. Be curious what those seats weigh. They look stout.
  19. #87
    Nov 2020
    New Zealand
    How much padding do they have in the seat.
    For years Ive put up with seats that jar my spine with every wave?
    Im about to build seats that have the seat foam 7 inches thick? so more or less from the floor up
  20. #88
    Dec 2019
    Lake villa Illinois
    23 pounds I believe. So still quite a bit lighter than a skater style high back seat. The previous fiberglass racing seats I had were about 19 pounds. Those had steel brackets though.
  21. #89
    Dec 2019
    Lake villa Illinois
    They seem comfy, lot of padding on the front where your legs sit. On the butt area not so much. But at the end of the day they are a racing seat for cars really. I’m not offshore racing or anything but Lake Michigan does get pretty rough. I’ve always wanted to try out some of the suspension seats they make from x craft. X craft competition seats. I’m sure they are cheap! 😂
    Attached Thumbnails Attached Thumbnails C5395E04-5D96-4B4F-93DD-BCB6CA9858E8.jpeg   A52151B0-F872-4900-A75B-47C17C29CE5A.jpeg
  22. #90
    Jul 2004
    Connecticut
    I always wondered if something simple could be fab'd up ..........
    Attached Thumbnails Attached Thumbnails MiniSeatSpringFront.jpg   SeatShockAbsorbers.jpg
