Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 121 to 135 of 138
  1. #121
    Dec 2019
    Lake villa Illinois
    Panels are in and shifter mounted. Just need to trim seat brackets.almost there !
ID:	487377   Click image for larger version.
ID:	487378   Click image for larger version.
  2. Likes tnelsmn liked this post
  3. #122
    Dec 2019
    Lake villa Illinois
    Just waiting on power purge for steering abs gas fill hose
ID:	487401   Click image for larger version.
ID:	487402   Click image for larger version.
ID:	487403   Click image for larger version.
  4. Likes tnelsmn liked this post
  5. #123
    Jul 2004
    Connecticut
    You have been rolling big time. Looks great!
  6. Likes Pepperson4 liked this post
  7. #124
    Dec 2019
    Lake villa Illinois
    Got the foot throttle mounted and steering bled finally. Motor fired right up as expected. Just need prop hub and Ill drop her in
ID:	488130   Click image for larger version.
ID:	488131   Click image for larger version.
ID:	488132   Click image for larger version.
ID:	488133   Click image for larger version.
ID:	488135   Click image for larger version.
ID:	488136   Click image for larger version.
  8. Likes berat, scott reierson, tnelsmn liked this post
  9. #125
    Dec 2019
    Lake villa Illinois
    Been on the boat all week. First test run went pretty good. After playing with jack plate heights and trim settings we found a decent spot. Running a 26p raker HO currently. First day it seemed bow heavy so I took the subs out (80lbs) next day we threw some vests on and really aired it out. Were able to hit 75mph at 6,010 rpm pretty close to limiter. I plan on finding a 30p pro max To try bad break into the 80s! Got the seadek on as well. This thing laughs at the chop. The g2 makes some great power too. The whole shot is incredible. Super nice to be able to switch from hand to foot throttle also
ID:	488646   Click image for larger version.
ID:	488647   Click image for larger version.
ID:	488648   Click image for larger version.
ID:	488649   Click image for larger version.
ID:	488651   Click image for larger version.
ID:	488652   Click image for larger version.
ID:	488653   Click image for larger version.
  10. Thanks Greg G thanked for this post
    Likes Greg G, tnelsmn, scott reierson liked this post
  11. #126
    Jul 2004
    Connecticut
    Congrats, your mad skills just converted to mad fun fun fun
  12. Likes Pepperson4 liked this post
  13. #127
    Minneapolis MN
  14. Likes Pepperson4 liked this post
  15. #128
    May 2021
    New Hampshire
    This is gorgeous!
  16. Likes Pepperson4 liked this post
  17. #129
    North Carolina
    Great job. Looks super cool.
    You cannot bring about prosperity by discouraging thrift. You cannot strengthen the weak by weakening the strong. You cannot help the wage earner by pulling down the wage payer. You cannot further the brotherhood of man by encouraging class hatred. You cannot help the poor by destroying the rich. You cannot keep out of trouble by spending more than you earn.
  18. Likes Pepperson4 liked this post
  19. #130
    May 2001
    Madison, WI
    Congratulations! You did a great job on that boat. 75 1st time out! Nice! Looks like the Grass Lake road bridge in the back ground of one of those shots.
    Many of the 250 E-TEC owners I was involved with never had a problem with them and are still going. Best of luck to you!
  20. Likes Pepperson4 liked this post
  21. #131
    Dec 2019
    Lake villa Illinois
    Quote Originally Posted by scott reierson View Post
    Congratulations! You did a great job on tht boat. 75 1st time out! Nice! Looks like the Grass Lake road bridge in the back ground of one of those shots.
    Yessir I always launch in grass lake! Usually the best for speed runs
  22. #132
    Dec 2019
    Lake villa Illinois
    Here’s a couple clips of it rippin. Still need to get the decals on and finish some odds and ends but every time I go to do anything on it I just end up taking it out to run ��
    https://youtube.com/shorts/LhwhIEtHApE?feature=share
    https://youtube.com/shorts/AXFFDY0eMH0?feature=share
  23. Likes tnelsmn liked this post
  24. #133
    Dec 2019
    Lake villa Illinois
    Getting the lettering ordered up. This is the rendering of what it should look like. Took 2 others out the other night and it definitely flew the bow better with a person in back. 50% trim is the neutral point. Im driving at 80% trim most of the time. I plan on adding 4 of setback on the jack plate. Im currently at 10 of setback with the built in 4 of the g2 plus my 6 jack. 14 should be a good spot Im thinking, hopefully will move CG back so I dont have to trim it so much to fly the bow.
ID:	489438   Click image for larger version.
  25. #134
    Jul 2004
    Connecticut
    You seem to have a pretty complete garage set up. If you have a lift why not put a sling under it and move it up off the trailer a few inches until you find the CG? Easy to do if you are equipped and may shorten the experiments.
  26. #135
    Dec 2019
    Lake villa Illinois
    No lift unfortunately. Just an engine hoist.
