Page 8 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 106 to 120 of 145
  1. #106
    Dec 2019
    Lake villa Illinois
    Seats are in
    Attached Thumbnails Attached Thumbnails 1F08DEE7-B975-4E2C-B484-68F038221A40.jpg   B13440C1-A6EF-4C0D-895D-148C4BF6FD8F.jpg   EC77881F-7CBA-4A6F-8893-E8C721F2D092.jpg
  2. Likes tnelsmn, 89LASER liked this post
  3. #107
    Dec 2019
    Lake villa Illinois
    Bench is almost done
    Attached Thumbnails Attached Thumbnails 6BFA2B5E-04C7-4DBF-9913-0C65A4AA74EC.jpeg
  4. #108
    Dec 2019
    Lake villa Illinois
    Cleats are mounted and ready. Went with a 6” accon pop up. So this is the 3rd cleat I’ve had in this boat. As you can see I’m very indecisive 🤡😅. Also having a full cover made. Hopefully get the floor done soon and fire it up after I bleed the steering.
    Attached Thumbnails Attached Thumbnails 9B6D4428-1B84-41CC-A555-D0FD048CF654.jpeg   6330F3CD-EA4E-4B80-B597-033E1E215875.jpg   34FBE022-38F0-4D34-9776-114EE6284298.jpg
  5. Likes tnelsmn liked this post
  6. #109
    Dec 2019
    Lake villa Illinois
    Bench is done. Sanded floor back down to primer and reprimed and spray a single reduced layer of raptor liner. I like the durability of it over Gelcoat. I only sprayed 4mils worth of coating roughly. Figured it would be even easier to sand off than a thick layer of gel if a repair was ever needed. I only prayed around where seadek willl be going, rest of floor and bulkheads and bilge remain white.
    Attached Thumbnails Attached Thumbnails 18D4DD77-66E6-48ED-B2CB-10E2093DDDD5.jpeg   5E94FDF7-2F3C-45AE-86E1-257F2200657D.jpg
  7. Likes tnelsmn liked this post
  8. #110
    May 2001
    great south bay
    How far of a reach is that paddle switch attached to the helm with your set up? I ran into that myself using a seastar helm. You need to take your hand off the wheel to reach it, Those are made for their own Uflex helm where they mount up closer to wheel. I am making a spacer to move it out.
  9. #111
    Dec 2019
    Lake villa Illinois
    Quote Originally Posted by 2.5-21 View Post
    I just added a strip of rubber between it and the helm so I could move it closer a bit and it would still tighten down.
  10. Likes 2.5-21 liked this post
  11. #112
    Dec 2019
    Lake villa Illinois
    Comin along
    Attached Thumbnails Attached Thumbnails EE5FB558-73B8-433A-B7B1-D69B46023B79.jpg   F09309A8-1ECA-4DF2-8106-0B7098D224A5.jpg
  12. Likes tnelsmn, noli liked this post
  13. #113
    Dec 2019
    Lake villa Illinois
    The original panels cracked when I dropped one. It was a bad design, the the pvc board I made too narrow of a piece by the cubby/speaker. That left it very weak. So I redesigned and built new panels. Just finished covering them.
    Attached Thumbnails Attached Thumbnails B74EE741-D3E9-4372-ABF2-66DCCE7B34EA.jpg   C1A3BDFF-FDC5-4CDD-AE38-3824B78066D3.jpg
  14. Likes tnelsmn, Velocity72 liked this post
  15. #114
    May 2001
    Madison, WI
    Do you know how heavy did that panel turn out using the PVC board?
    Looks great and won't rot
  16. #115
    Dec 2019
    Lake villa Illinois
    Quote Originally Posted by scott reierson View Post
    13 pounds each. That’s using 1/2” foam. 3/8” pvc board. 5/16 2” bolts with 2” fender washers and a T nut on the back to hold them in.
  17. #116
    Dec 2019
    Lake villa Illinois
    Comin along
    Attached Thumbnails Attached Thumbnails FA8D6B57-A69F-4904-A31C-09BF7E002635.jpg   F8B3A3C3-C3C8-42F6-9EEA-6DCCA184A83A.jpg
  18. #117
    Dec 2019
    Lake villa Illinois
    Panels are in and shifter mounted. Just need to trim seat brackets.almost there !
    Attached Thumbnails Attached Thumbnails 51AFA04B-F517-49FC-B9BD-7CF6042DED5E.jpg   5014942C-250F-4D92-8DC1-A64C2284F8C1.jpg   FECAD024-6834-4188-BF99-BBFD5BC5AA02.jpg
  19. Likes tnelsmn liked this post
  20. #118
    Dec 2019
    Lake villa Illinois
    Just waiting on power purge for steering abs gas fill hose
    Attached Thumbnails Attached Thumbnails D120F294-A3C8-44F5-B201-4D8EC97755E8.jpg   A46A6DC1-B4DE-490E-A46E-1725B903CBB5.jpg   4655A9ED-7A9C-47B7-8E61-89B275A722E0.jpg   D2086BE1-6623-4A70-B0D6-8BA28B194B97.jpg
  21. Likes tnelsmn liked this post
  22. #119
    Jul 2004
    Connecticut
    You have been rolling big time. Looks great!
  23. Likes Pepperson4 liked this post
  24. #120
    Dec 2019
    Lake villa Illinois
    Got the foot throttle mounted and steering bled finally. Motor fired right up as expected. Just need prop hub and I’ll drop her in
    Attached Thumbnails Attached Thumbnails 11BC0C7D-BB23-4F94-A877-B25141B84095.jpg   7D51E9B4-6B2A-4C6C-A7CD-EF2DC5A5C99A.jpg   D7E614A6-B6BE-4EA8-9E6B-975ECC6B6982.jpg   0F9895A4-6F39-4CBB-8131-BB84BAEE0540.jpg   6A8C39FC-1A92-40D2-882C-06D00DBF2936.jpg
    4D02B784-52BF-4BCC-BEF6-53BDE5806370.jpg   E35A0EF4-6A19-4858-B5C7-90A273E0C8A5.jpg   0163A6C4-11D5-4365-A54D-066FEEAB5739.jpg
  25. Likes berat, scott reierson, tnelsmn liked this post
