Results 1 to 5 of 5
    May 2005
    Louisiana
    Looking for a 1999 evinrude ficht emm
    davepnola
    5000 RPM
    Join DateMay 2005LocationLouisianaPosts183Thanks (Given)0Thanks (Received)0Likes (Given)0Likes (Received)0Mentioned0 Post(s)Tagged0 Thread(s)
    Emm for Evinrude... 1999 Ficht 150
    I have a 99 150 ficht has had the pins done on the heads so it’s been updated .
    my emm is bad starts when cold , idle is all over the place , no faults , once the emm gets hot , engine will not start until it completely cools off ... also when it does not start it will not communicate through Evinrude diagnostics ..
    I guy sold me a 225 telling her it was a 150-175 .. he lied , so that did not work , I even tried to clone it to a 150hp still did not work , but it was good it communicated and I downloaded the emm file .. so I have this one , and also I have another emm. Looks like for a 90 -115 ...,
    So I am looking to trade these 2 fior a good emm with the update for my 1999..150 ficht ... let me know Dave 504-234-4458
    also why is the emm with the black plastic and other plug ins listed for 135-250 hp ?
    the plugs in my harness fit in the emm ? Are these Emms interchangeable?
    Attached Thumbnails Attached Thumbnails 9CA87277-E1CB-4E1E-AB2D-6B7DE60A28A7.jpg   039CE66F-DEA3-4FC8-BFFB-0A591D2CBC55.jpg
    Nov 2019
    Canada
    Why don't you send it off to be repaired? I think you will have a hard time finding a good used EMM for that motor.
    www.InjectorService.com
    Call/Text - 204-326-0390
    May 2005
    Louisiana
    I probably will , it will be the second time so I will use a different repair center ... just was hoping someone had one to trade for these 2 ... both are good ... mine still runs but it must have a bad solder joint or capacitor... it’s wild on idle cold ... will run all day , but if U turn it off ... it will not start again until the next morning or a complete cool down ...
    Nov 2019
    Canada
    Where'd you send it last time?
    May 2015
    slc utah
    You might keep an eye on "BassBoatCentral" forums as well
    I see more there.. Im running a 1999 150, Ficht however, until it dies I wont be giving up any parts. Although I do have a lower unit.....
  1. OMC Tech: Emm for Evinrude... 1999 Ficht 150
    By davepnola in forum Technical Discussion
    Last Post: 08-06-2020, 06:26 PM
  2. 1999 Evinrude 200-225 Ficht cowl
    By Kyle Lewis in forum Misc. Parts and Accessories
    Last Post: 03-28-2019, 03:11 PM
