Results 1 to 7 of 7
    Feb 2016
    Nags Head NC
    Trim Pump Fluid Advice
    I just woke up my 89 Mercury 150 from it's winter sleep yesterday. It was a glorious cloud of Seafoam blue smoke that filled the yard I'll be doing all the usual maintenance for the the season but was wondering if I should try to change the trim pump fluid. Ive had the engine for a few years now and have never had a problem or leak, it's the three ram style. I'm kind of a if it aint broke don't fix it kind of guy. But if I should any tips or techniques would be helpful and also suggestions for type and brand of fluid. The wife and i were taking the Checkmate out this weekend but typical Outerbanks weather, it went from 70* to 50* overnight.
    Jan 2015
    If it is the original fluid from 1989, I would change it. If unsure how old it is, what does it look like? I would probably change it if unknown.
    It may be just me, but I change those things every so often, depending on use. For what it costs and the time it takes, I feel better knowing that I am running clean fluids.
  3. Thanks James Thompson thanked for this post
    ATF
  5. Thanks James Thompson thanked for this post
    Likes tux974 liked this post
    Sep 2017
    Ashland city tn
    I agree on the atf fluid. Seems to run a bit faster than oil also
    Houston, TX
    Type F or Dex Merc?
    Quote Originally Posted by rgsauger View Post
    Type F or Dex Merc?
    Don't matter, I use full syn for our cold spring and fall mornings.
  9. Likes Merc 2.5 liked this post
    Houston, TX
    Thanks Dave
  1. Merc trim pump fluid level low....?
    By Keaten in forum Technical Discussion
    Last Post: 02-25-2017, 03:10 PM
  2. Trim Pump Fluid
    By harrells in forum Technical Discussion
    Last Post: 09-23-2011, 10:08 PM
  3. Trim pump fluid
    By Jeff "Yammer" in forum Technical Discussion
    Last Post: 06-07-2006, 08:57 AM
  4. Fluid for trim pump
    By STV_Keith in forum Technical Discussion
    Last Post: 12-08-2002, 01:47 AM
  5. SIMPLE QUESTION - Trim Pump Fluid
    By G-Train in forum Technical Discussion
    Last Post: 07-14-2002, 01:38 AM
