Results 1 to 4 of 4
04-10-2020, 12:31 PM #16000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
MAY need to lower motor 20'' transom/ 15''2.4
need some ideas how to lower motor, dont want to cut transom. its a tunnel and cone might be too high when i get it flyin. im looking at a cmc55012 plate, but i cant get ah.p. rating pic show travel 2''up erom stock &2'' below stock. can i just reverse mount a 6'' jplate?i wont need to tilt for trailering. set-back brackets all raise motor, could i rotate them so motor drops?
04-10-2020, 07:35 PM #2
Have never tried it , bolts holes need be changed , but seems like piece a steel is piece steel (aluminum) no matter how its bolted ???
04-10-2020, 07:52 PM #3
The pattern will be bass~akwards. No big deal, there's more than enough meat on those plates to drill two or three patterns if you really wanted.
Accurate measurement's, a scribe, sharp center punch, and a transfer punch will make for a nice job of it ..
KIRCHNER thanked for this post
04-13-2020, 10:09 AM #46000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
ISounds like a plan, i have the tools, thankx After searching i found a drop down 2pc plate o- 4'' down, exactly what i need made in tennessee, a new product. vance mfg. #ddpl6375. 6''' setback. manual adjust. handy if you have a 15''v-6!
Motor stuck to transom
By ROLF in forum Technical DiscussionReplies: 14Last Post: 10-06-2010, 09:48 PM -
Motor pattern in Transom???????
By 1FASTLASER in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 09-01-2008, 12:35 PM -
Motor height on transom?
By 82RAYSONCRAFT in forum Technical DiscussionReplies: 2Last Post: 09-16-2005, 05:15 AM -
How do I get my motor seting plumb on my transom
By 1badskeeter in forum Technical DiscussionReplies: 0Last Post: 05-31-2005, 05:56 PM -
Crooked Motor on the transom, what does this do to performance?
By tonye in forum Technical DiscussionReplies: 24Last Post: 03-23-2002, 10:31 AM
