Results 1 to 7 of 7
04-09-2020, 02:12 PM #1Member
- Jan 2020
- NY
- 72
Hydraulic jack plate vs. Manual Jack Plate
I realize I hydraulic plate is much easier to dial in and help with prop setup. Can a manual plate properly set up match it in performance or is the extra lift a hydraulic gives add a few more miles per hour thanks
04-09-2020, 04:53 PM #2
I think some boats are quicker & faster with the motor at different heights... so they launch with the motor down and raise it when they get up to speed (not for amateurs like me). You can't do that with a manual plate. I took my hydraulic jackplate off because it's heavy and I didn't use it that way.
04-10-2020, 09:24 AM #35000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
I had a Hydraulic jack on my Baja and loved it. When I purchased my Euro I was under the impression in reading the various forums that with the Euro you basically set the height 1.25-1.75 and leave it so I when with a Bobs manual jack. I have 4 different props now... a Lightning ET, 3 different cleavers, both 3 blade & 4 blades and wish I had the hydraulic plate especially with a few passengers.
21CheckmateLD thanked for this post
04-12-2020, 10:39 AM #4
I like the weight difference in manual but u cant beat hydraulic for dialing in with water conditions and boat weight (passengers etc.) Changing day by day unless u run mostly alone
KIRCHNER thanked for this post
04-12-2020, 03:37 PM #5Team Member
- Lake Coochiching, Ontario
- 7,753
- 271
- 485
- 1571
- 6 Post(s)
I had a manual plate on a 16’ Baja and that was fine. My SS2000 is much more sensitive to height, load, waves, so I like hydraulic for it.
04-12-2020, 06:07 PM #6
04-12-2020, 08:45 PM #7Team Member
- 7,753
- 271
- 485
- 1571
- 6 Post(s)
My Baja was a 16’ with a narrow pad. Up or down an inch didn’t change much, nothing measurable with gps
looking for ideas - Manual trim indicator fot Hydraulic Jack Plate
By Pachanga_rick in forum General Boating DiscussionReplies: 8Last Post: 08-05-2016, 03:30 PM -
Manual Jack Plate vs Hydraulic Jack Plate
By Burchoid in forum Props, Setup, and RiggingReplies: 9Last Post: 05-25-2012, 05:00 AM -
Jack Plate Problem - Manual Rapid Jack
By croSSed in forum Props, Setup, and RiggingReplies: 0Last Post: 06-30-2008, 11:43 AM
