Results 1 to 3 of 3
    Jul 2011
    Jupiter, FL
    Surfacing Prop in only 17" pitch?
    Does anyone know of a lower pitch prop, around 17"P, that can run piercing the surface.
    I have a 26 ft Andros with a 300 Yamaha on a Porta Bracket. The boat only does in the high 40's so I am not looking for more speed. I want to be able to jack to motor up for running in shallow areas.
    20ft Lake & Bay Custom "Low Altitude" w/ 300xs
    Feb 2010
    wisconsin
    prop
    Quote Originally Posted by Air&Sea View Post
    I would buy a Bravo 1 LT in 19 pitch and then pitch it down to 17.5 or so.. plus those blades are pretty robust so if your running shallow they will be able to run through a little sand and silt and not get to damaged.
    CHAIN O LAKES, IL
    Rev 4 xp
    Look into the merc REV 4 XP .....
  1. Prop cupping for surfacing....Questions?
    By olboatman in forum Props, Setup, and Rigging
    Last Post: 04-30-2015, 12:45 PM
  2. Replies: 1
    Last Post: 12-16-2014, 01:35 AM
  3. Parker racing prop 9 1/8" x pitch unknown...15"?? $50.00
    By Marchettih2o in forum Propellers
    Last Post: 08-01-2014, 08:43 AM
  4. "Surfacing " a prop - damage cupping ?
    By Mike Prickett in forum Props, Setup, and Rigging
    Last Post: 07-22-2010, 04:01 PM
  5. Dual cable steering with surfacing prop?
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 06-22-2010, 02:53 PM
