Results 1 to 8 of 8
    Mar 2020
    netherlands
    What kind of signal is the tachometer using?
    hello,
    I was wondering, what kind of signal does a mercury 2 stroke produce for the tachometer? (so the grey wire coming from the regulator/sender unit). I assume this is a square wave of which the frequency is going up as you hit the throttle?
    I want to know the specs of this signal.
    -What is the duty cycle (50/50? or does this change if the revs go up)
    -I assume the signal is 12V pulse (going from 0V to 12)
    -What are the frequencies of the signal when idling, and on full throttle?
    -Is the frequency linear with the revs of the engine? So for instance, if the engine was turning 1000 rpm, would the frequency be 1000Hz?
    MIAMI FLORIDA
    1 hz = 60 rpm, so divide your rpm by 60 to get hz then multiply this value times pulses per rev of the stator on your engine, V6 =12 pole alternators =6pulse per rev. sine wave output im not positive on newer stuff but most only use one diode in the rectifier so around +0-9v on each pulse... 1000rpm=100hz/6000=600hz
  3. Likes TEXAS20225 liked this post
    Mar 2020
    netherlands
    Thanks. I have a 115 merc 2 stroke 4cyl. So does this one have 8 pole alternator? I assume that the signal going to the tachometer is dc (12V pulse). Where is the 9 v coming from?
Name:	Screenshot_20200406-194905_Samsung Internet.jpg
    MIAMI FLORIDA
    Should still be 12 pole and 6 pulse per revolution, look at the tachometer charts online for your engine year see what they call for, honestly havent worked on one of those in years, most of the motors above 70hp use 12 pole, rude and merc... 6 pulse from a 12 pole alternator tells you they are only using 1/2 the diode bridge so you will get around 1/2 the dc voltage since you are using everyother +peak on the sine wave, pulsed dc lol.. max is around 18v at wot so u get 9ish depending on rpm idle will be much lower.. A square wave would be digital. Hope this helps... Dave
    Feb 2013
    Northern Cal
  7. Likes H2OPERF liked this post
    MIAMI FLORIDA
    Plus you loose about .6-.7 volt thru a diode. The newer electronic stuff like omc watercooled still use the same 6 pulse at around 9v not sure exactly whats goin on inside those to get the output..
    Jan 2003
    aalsmeer
    at 6 pulses per crank rotation times 1000 rotations per minute would be 6000 pulses per minute divided by 60 seconds is 100 pulses per second or 100 Hz but my math could be wrong
  10. Likes H2Okie liked this post
    Feb 2013
    Northern Cal
    Great video for illustration and yes your math is correct . For me it's easier to keep straight by first taking the rpm's value 1000 and divide 60 to convert to revolutions per second RPS = 16.67 and then multiply by pulses per revolution ( 6)
    16.67 x 6 = 99.99 or 100 PPS /Hz
    But that's just me .
  1. 260 tacho signal
    By Sjefen in forum Technical Discussion
    Last Post: 03-09-2015, 03:54 PM
  2. 2.4 Tach Signal?
    By redpickle in forum Technical Discussion
    Last Post: 03-29-2014, 04:07 AM
  3. 280 tachometer signal
    By catfish123 in forum Technical Discussion
    Last Post: 04-16-2011, 06:51 PM
  4. Warning signal??? Maybe ecm??
    By Powmer in forum General Boating Discussion
    Last Post: 05-05-2009, 09:24 PM
  5. OMC Tach Signal
    By topwater in forum Technical Discussion
    Last Post: 02-27-2003, 06:11 PM
