Results 1 to 8 of 8
04-06-2020, 06:59 AM #15000 RPM
- Mar 2020
- netherlands
- 163
- 14
What kind of signal is the tachometer using?
hello,
I was wondering, what kind of signal does a mercury 2 stroke produce for the tachometer? (so the grey wire coming from the regulator/sender unit). I assume this is a square wave of which the frequency is going up as you hit the throttle?
I want to know the specs of this signal.
-What is the duty cycle (50/50? or does this change if the revs go up)
-I assume the signal is 12V pulse (going from 0V to 12)
-What are the frequencies of the signal when idling, and on full throttle?
-Is the frequency linear with the revs of the engine? So for instance, if the engine was turning 1000 rpm, would the frequency be 1000Hz?
04-06-2020, 09:10 AM #2
1 hz = 60 rpm, so divide your rpm by 60 to get hz then multiply this value times pulses per rev of the stator on your engine, V6 =12 pole alternators =6pulse per rev. sine wave output im not positive on newer stuff but most only use one diode in the rectifier so around +0-9v on each pulse... 1000rpm=100hz/6000=600hz
TEXAS20225 liked this post
04-06-2020, 12:53 PM #35000 RPM
- Mar 2020
- netherlands
- 163
- 14
04-06-2020, 04:43 PM #4
Should still be 12 pole and 6 pulse per revolution, look at the tachometer charts online for your engine year see what they call for, honestly havent worked on one of those in years, most of the motors above 70hp use 12 pole, rude and merc... 6 pulse from a 12 pole alternator tells you they are only using 1/2 the diode bridge so you will get around 1/2 the dc voltage since you are using everyother +peak on the sine wave, pulsed dc lol.. max is around 18v at wot so u get 9ish depending on rpm idle will be much lower.. A square wave would be digital. Hope this helps... Dave
04-06-2020, 06:23 PM #55000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
H2OPERF liked this post
04-06-2020, 06:56 PM #6
Plus you loose about .6-.7 volt thru a diode. The newer electronic stuff like omc watercooled still use the same 6 pulse at around 9v not sure exactly whats goin on inside those to get the output..
04-07-2020, 12:30 PM #7
at 6 pulses per crank rotation times 1000 rotations per minute would be 6000 pulses per minute divided by 60 seconds is 100 pulses per second or 100 Hz but my math could be wrong
H2Okie liked this post
04-07-2020, 01:42 PM #85000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
Great video for illustration and yes your math is correct . For me it's easier to keep straight by first taking the rpm's value 1000 and divide 60 to convert to revolutions per second RPS = 16.67 and then multiply by pulses per revolution ( 6)
16.67 x 6 = 99.99 or 100 PPS /Hz
But that's just me .Last edited by H2Okie; 04-07-2020 at 01:45 PM.
260 tacho signal
By Sjefen in forum Technical DiscussionReplies: 1Last Post: 03-09-2015, 03:54 PM -
2.4 Tach Signal?
By redpickle in forum Technical DiscussionReplies: 7Last Post: 03-29-2014, 04:07 AM -
280 tachometer signal
By catfish123 in forum Technical DiscussionReplies: 0Last Post: 04-16-2011, 06:51 PM -
Warning signal??? Maybe ecm??
By Powmer in forum General Boating DiscussionReplies: 1Last Post: 05-05-2009, 09:24 PM -
OMC Tach Signal
By topwater in forum Technical DiscussionReplies: 24Last Post: 02-27-2003, 06:11 PM
