Results 1 to 7 of 7
    Sep 2006
    Miami, Fl.
    Question 98 225 Pro Max Oil Injection Removal issue
    Hi,
    a. Got all the oil injection stuff out. When inserting the new plug kit feels as its free, I remember on previous set-ups you can feel when the pump gear gets blocked. I bought part #43453 and today did some google search and find there is a part#43453(T) is there a difference or superceeded? or this is it ?
    b. In the other hand I was looking were the bleed tubing is supposed to connect in the cylinder block but there is no valve exits??? or is it pluged in a different place???
    New to PM engines appreciate your help .
    Thanks,
ID:	462259Click image for larger version.
    Mar 2004
    vonore tn.
    Yes that is correct part, for plugging oil drive. The bleed tubing you are talking about, is actually the pulse fitting, that pressurizes the oil tank in boat, to send oil to tank on motor. Remove all that And use 1/2 pipe plug to block off port, on bottom starboard of intake manifold. Use good 2 stroke oil, that I prefer to mix at 40 to 1. Or 1 pint at 5 gallons. For high RPM use.
    Sep 2006
    Miami, Fl.
    Hi Billybob,
    Thanks for your response. When I trash oil injection stuff there should be an oil bleed tubbing between engine cilinders that I dont find exits (see pic)
    Quote Originally Posted by billybob View Post
    Make sure there is an o-ring on the new plug. Bleed system has nothing to do with oil injection, leave it be.
  5. Likes tux974 liked this post
    TX......somewhere?
    Quote Originally Posted by rarias View Post
    Hi Billybob,
    none of those have anything thing ta do with oil injection.. those are "bleed" lines from reed plate to vst for fuel system... a 225 PM does not have any bleed bibs on tha cylinders.....
  7. Likes tux974 liked this post
    Sep 2006
    Miami, Fl.
    Thanks Dave. Will make sure o ring is installed.
    Quote Originally Posted by Dave Strong View Post
    Sep 2006
    Miami, Fl.
    We all set!! No bleed lines in 225 PM.
    Thanks
  1. Oil injection removal
    By cajunman72 in forum Technical Discussion
    Last Post: 01-10-2010, 02:00 PM
  2. oil injection removal
    By Bones in forum Technical Discussion
    Last Post: 01-03-2003, 09:43 AM
  3. Oil Injection Removal
    By gw204 in forum Technical Discussion
    Last Post: 11-02-2002, 10:20 AM
  4. OIl Injection Removal
    By CNT in forum Technical Discussion
    Last Post: 03-16-2002, 01:07 PM
