Results 1 to 15 of 17
    Plainville, CT
    Mercury XRI System
    Anyone have an opinion on the XRI system. Looking at it seems pretty simple and may work well.
    Florida Keys
    Laser setups are awesome......that’s why Mercury made them
    '95 STV "The Blue Goose"
  3. Thanks Glastron1987 thanked for this post
    Sep 2017
    Ashland city tn
    Ya the laser setup one most reliable I believe and with mods can be made run great. Like with slide or sumthin on it
  5. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
    Aug 2012
    beaumont, tx
    love mine
  7. Thanks Glastron1987 thanked for this post
    Plainville, CT
    Quote Originally Posted by Merc 2.5 View Post
    What kind of mods are you talking about? What is slide?
    Aug 2012
    beaumont, tx
    mods= ..bigger bore butterfly..non-progressive linkage... and SVS or slide that bolts on front allowing air in through front
  10. Thanks Glastron1987 thanked for this post
    Likes Merc 2.5, Glastron1987 liked this post
  11. #7
    Carbs FTW unless you go crank case injection. 1
  12. Likes mach351, Merc 2.5, mrichartz liked this post
  13. #8
    Florida Keys
    I hear ya Capt.....even with my first response.....I’m still a carb guy to the bone
  14. #9
    Aug 2012
    beaumont, tx
    you 2^^^^^....should of known
  15. Likes mach351 liked this post
  16. #10
    Plainville, CT
    Crankcase injection... is that the full EFI?
  17. #11
    Pekin, IL
    Laser injects in front of reeds and crankcase is behind reeds. They are both EFI.
    Rock
    Team Junk
  18. Thanks Glastron1987 thanked for this post
  19. #12
    Plainville, CT
    Quote Originally Posted by rock View Post
    Rock
    So I take it that Laser is another name for XRI?
  20. #13
    Pekin, IL
    It is. Kinda like the dif tween throttle body and TPI. Laser is wet reed and crankcase is dry reed. Both work very well if ya know what you're doing and have the diagnostic tools and corresponding ability. Carbs are usually much easier when trying to diagnose issues and require no special tools.
    Rock
    Team Junk
  21. Likes specboatops, Baker343, tux974 liked this post
  22. #14
    Plainville, CT
    Rock
    Great thanks. So I'm going to guess that XRI/Laser/wet reed injection requires fewer special tools than dry reed injection, or is it really about the same?
  23. #15
    Pekin, IL
    I would think they are about the same. There may be fewer parts on the crankcase system but they are so different it's hard to compare. You're trying to read the computer function either way.
    Rock
    Team Junk
  24. Thanks Glastron1987 thanked for this post
  1. Mercury 40 amp CDM system
    By Varmint in forum Misc. Parts and Accessories
    Last Post: 12-08-2015, 05:05 PM
