Results 1 to 6 of 6
04-04-2020, 08:59 AM #1
Fuel lines and quick connect fitting at motor
So with all the conversations about fuel line types and sizes, here's another question. Are folks still running the bayonet quick connect on the fuel line at the Mota or taking it out and running directly to the carbs, efi?
Mine is fed on each side by 3/8 but sure looks like a heckuva restriction in the coupling itself compared to the hose feeding it.Last edited by rgsauger; 04-04-2020 at 09:01 AM.
04-04-2020, 09:21 AM #2
No, no quick connect
rgsauger thanked for this post
04-04-2020, 10:05 AM #3
Ifin it's got these holdin the motor on ....
Then it's OK to use this …
I haven't seen one of these ends since I was a kid .. when life was simple ..
04-04-2020, 02:56 PM #4
Thanks guys. It's outa' here!
04-04-2020, 08:52 PM #5
Thanks . Going to run 3/8 from tank to pump.
04-05-2020, 07:34 AM #6
Ya only thing that's got one those round here is the merc 25 4 stroke, so small tanks can swapped around easy. They leak like crazy after while
Best tubing for bleed lines/small fuel lines 2.4 MERC
By rujr in forum Technical DiscussionReplies: 25Last Post: 07-10-2013, 10:26 AM -
Quick fitting adjustment question re. Seastar pro
By diamond-back in forum Technical DiscussionReplies: 2Last Post: 01-20-2013, 10:48 PM -
Where do these oil lines connect?
By RUNWME in forum Technical DiscussionReplies: 11Last Post: 08-31-2004, 09:43 AM
