Results 1 to 14 of 14
Thread: 260 has spark, fuel, won't run
04-02-2020, 01:04 PM #15000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
I'm having some problems with a new to me 260. I bought the motor as a rotating assembly. I put electronics on from a running carb motor and added an injector harness. The motor wont run unless you spray gas into the horn. I've checked timing, changed the injector harness to a new Wizard harness, changed fuel sources, pulled all injectors and verified that they are spraying. I'm not sure what I'm missing.
04-02-2020, 01:29 PM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
r u using a fully charged battery? everything grounded?
04-02-2020, 01:32 PM #35000 RPM
- Jun 2002
- Vancouver, BC
- 882
- 32
- 27
- 52
- 99
ECU or ECU power source is my bet... what ECU are you using?
Mike Nass
Haulin Nass RaceBoats (HNR)
www.haulinnassraceboats.com
e-mail - MikeNass@shaw.ca
phone - 604-230-4835
04-02-2020, 01:40 PM #4
He's got an A63. Had it checked with a 4 button, and it will read it. He can try an A13 he can rob from another boat at his house to test it I guess.
Could it be the switch boxes?"The Flying Clamato"
...This ain't no Party, This ain't no Disco, this ain't no foolin around..."Talking Heads - Life During Wartime"
The G-Train has left the station.
04-02-2020, 03:13 PM #55000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
I have the ECU power run off the ignition switch and verified that it is getting power. I also tried running it straight from the battery and no change. I changed outer switchbox to a known good one and no change. I've also verified that it is getting spark.
04-02-2020, 05:24 PM #65000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
Figured the problem out. My tee for the fuel return line was too big and letting too much fuel by. I searched all over for a factory tee but couldn’t find one. Does anyone know where to get one?
04-02-2020, 06:13 PM #75000 RPM
- May 2004
- Eastern PA
- 594
- 29
- 54
04-03-2020, 07:51 AM #8Supporting Vendor
- 11,838
- 163
- 11
- 795
I’d dial indicate the motor on All holes go to perfect TDC turning clockwise then when that is confirmed turn counter clockwise to .150” and MARK flywheel across from static pointer , advance the timing to total timing , turn over and over at full advance shoot timing light confirming spark at proper time on ALL holes best was to confirm switch box and igniting health !!
Jay @ JSREJay @ JSRE
04-03-2020, 07:54 AM #9Supporting Vendor
- 11,838
- 163
- 11
- 795
You question about the RED ( reducing ) TEE its is a must to use that proper tee I bought the last 3 about a a month ago from OEM , I’d figure they would have restocked ????
JayJay @ JSRE
04-03-2020, 09:52 AM #10
04-03-2020, 12:16 PM #11Supporting Vendor
- 11,838
- 163
- 11
- 795
Yep the 3 I bought from Mercury was $48.00 list the warehouse he ordered from had 3 available I use them a hell of lot finding many clogged I bought a micro drill bit set thinking I could drill to speck !! WRONG I checked hole size with a known new one and the smallest bit mounted in a pin vise was to big , it that hole is drilled to big it will rob fuel rail of inventory and run motor lean ...
Been there and done that ,
04-03-2020, 12:20 PM #12Supporting Vendor
- 11,838
- 163
- 11
- 795
Racervboat ,
where on eBay did you score on those tees Did you pull up by part number or discription ?
JayJay @ JSRE
04-03-2020, 12:24 PM #131973 Viper - sold
1978 Viking - sold
1995 XB02
04-03-2020, 12:26 PM #14
Mercury Tech: 280 Ros has spark and fuel but won’t run
By John#24 in forum Technical DiscussionReplies: 0Last Post: 12-29-2019, 02:03 AM -
talk to me about fuel and spark plugs....
By cocacola in forum Technical DiscussionReplies: 5Last Post: 08-08-2012, 08:10 PM -
Merc 115, fuel and spark problems
By DEYS in forum Technical DiscussionReplies: 2Last Post: 06-16-2011, 07:17 PM -
spark or fuel??
By seebold1 in forum Technical DiscussionReplies: 9Last Post: 05-12-2004, 09:56 PM
