Results 1 to 2 of 2
03-31-2020, 02:14 AM #1
Crankcase stuffing on a 40 year old V4 140 OMC
Just doing some research on stuff the crankcase on a 40 year old Johnson 140.
I have read that the newer engines have less need for stuffing as this has been taken into account by the manufacturing & design system used nowadays.
The 140 comes with reed stuffers but what else can be done to de-crease the volume ?? Can the wrist pin be blanked off ??? Can the reed bed (Where it sits in the inl;ent manifold) have more work done with epoxy to help reduce the volume ????
What other things can be done ???
04-01-2020, 10:11 AM #25000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
There is really nothing else that can be done to crankcase of that motor too help much. You can plane heads, . 020 or .030 to increase compression. But then you will always have to run HIGH OCTANE FUEL. Also you can remove L/U and drill 4, 1/2 inch holes in top of L/U at exhaust tract area on both sides. That will make motor breathe better, but you may piss off other boaters with extra noise.
spybot liked this post
OMC Tech: Looper porting and stuffing crankcase?? Looper gurus
By Tinbanger1979 in forum Technical DiscussionReplies: 14Last Post: 12-21-2016, 10:09 PM -
Crankcase stuffing wrist pins
By Vinnie in forum Technical DiscussionReplies: 7Last Post: 10-23-2010, 10:21 AM -
stuffing the crankcase
By ironlake2 in forum Technical DiscussionReplies: 20Last Post: 11-27-2009, 10:31 PM -
Crankcase stuffing mods
By nz dave in forum Technical DiscussionReplies: 1Last Post: 06-09-2009, 02:35 AM -
Mercury Tech: Hey T REX (crankcase stuffing)
By Bryan Heaberlin in forum Technical DiscussionReplies: 21Last Post: 12-19-2008, 11:05 PM
