Results 1 to 8 of 8
Thread: Exhaust Plates
    Tampa, Florida
    Exhaust Plates
    Are the same year of 300 X exhaust plate interchangeable with that of an 300 XS? Thank you for any insight...
    24' Lorequin, Carson Prepped 250 EFI
    XS motors have a port drilled for a cooling line for the compressor.
    Tampa, Florida
    I have an X mid with a bad exhaust plate and have a chance to purchase an XS plate to put on it. Would this port be an issue? Could I fill it?
    Just put a pipe plug in it.
    Tampa, Florida
    Thank you Capt.
    Quote Originally Posted by fortlaudypower View Post
    Whats wrong with your 300x plate .. ???
    Got pics ...
    Tampa, Florida
    Mr. Chaz, the gentleman I purchased the mid from apparently had some trouble removing the block and studs. There is multiple holes drilled where each stud passes through the exhaust plate as well as a small portion of the lip where the lower skirt sits was broken during this as well. Sam
    I see , they used the "bigger hammer" principle ...
    Thank you for the response ..
  1. Replies: 2
    Last Post: 03-26-2020, 06:55 PM
  2. 3.0 Exhaust Plates
    By aalbert in forum Technical Discussion
    Last Post: 02-20-2004, 03:51 PM
