Results 1 to 8 of 8
03-28-2020, 05:01 PM #1Member
- Jul 2018
- up nort
- 35
90's Looper Compression when new?
What was the compression when new on the 3.0L V6's?
Can this be found in the manual? if so, where, as I didn't see it?
I've read these are low compression motors from factory (like 100-105lb psi).
Is there a technical buletin or something "official" out there? I need to settle a bet with a friend.
Thanks in advance
03-28-2020, 08:03 PM #2
Racer will know if he will chime in. Others will know also. I think it was certain yrs but I really cant tell ya. Not a omc guy
03-28-2020, 09:54 PM #3
What year? Yes they are low comp motors.
(until you do something to them..)
86-87 - 115#
88-92- 90-95# should be 90 but have seen 95 on stock too
93+ 110#
Yes it's in the manual too
MichaelLast edited by mrichartz; 03-28-2020 at 10:07 PM.
'84 Checkmate Convincor
03-28-2020, 10:44 PM #4Member
- Jul 2018
- up nort
- 35
Thanks guys.
The specimen in question is a 96, 225. I've got the manual but didn't see a "new" reading. The only thing I saw was under comp checcking they should be within 20% of each other. Any hints on where to find it in the manual?
03-28-2020, 10:56 PM #5
I don't remember where in the manual I'll look tomorrow
But was pretty sure it was in there.
The factory manual..
but I have a seloc with a bunch of notes I lend out.
And don't think it was in notes in the manual .. meaning I didn't write it so when someone borrowed it was in there..
If that makes sense..
MichaelLETS GO BRANDON.... LETS GO BRANDON
03-29-2020, 09:07 AM #6Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Factory manual does not list actual numbers that I remember. First you need to understand cranking speed will change compression numbers and gauges dont all read the same. I can tell you on my snap on gauge with and engine turning between 250 and 275 rpm on starter at sea level (air density) a 96 should be between 105 and 115 on a very rare one I have seen a bit over 115.
03-29-2020, 09:23 AM #7
If racer says it's not in there you have the answer..
I didn't look but don't have too now.LETS GO BRANDON.... LETS GO BRANDON
Merc 2.5 liked this post
03-30-2020, 11:57 AM #8Member
- Jul 2018
- up nort
- 35
appreciated
OMC Tech: Looper primary compression
By Captain75 in forum Technical DiscussionReplies: 57Last Post: 06-09-2017, 03:16 PM -
compression on 87 200 looper
By RUDE Attitude in forum Technical DiscussionReplies: 4Last Post: 06-20-2007, 01:06 PM -
v4 looper compression help
By oldschoolltv in forum Technical DiscussionReplies: 8Last Post: 08-09-2004, 10:00 AM -
looper compression
By j2somthin in forum Technical DiscussionReplies: 1Last Post: 02-28-2002, 07:01 PM -
OMC Looper Compression
By DSP1 in forum Technical DiscussionReplies: 3Last Post: 02-27-2002, 02:52 AM
