Results 1 to 8 of 8
    Houston, TX
    What are you guys running for a tach?
    My merc tach died in my Shadow after my voltage reg took a chit and sent more volts than it should have through it. Looking at replacements. Probably won't turn much over 7K. What are you guys running for tachs? Is there a simple 2:1 adaptor for an auto tach?
    Houston, TX
    Bump?
    May 2014
    Livingston, Louisiana
    I’ve been using the auto meter carbon fiber line of gauges and have been really pleased. Had some others complain about the auto meter gauges with the red needles having a fading problem. These are silver and have had zero issues with them.
    Attached Thumbnails Attached Thumbnails B9F98940-9284-49B4-BE38-317C2F1CBF0F.png
  4. Thanks rgsauger thanked for this post
    Nov 2009
    Netherlands
    I use the Merc gauges, no complaints, but they are not as fancy as the autometer gauges (no recall, etc)
Name:	2019-09-07 18.00.57.jpg
  6. Thanks rgsauger thanked for this post
    Houston, TX
    Thanks guys. Does anyone know if there is a simple "adapter" of sorts to be able to run an automotive tach on a V6 outboard? I have an Autometer but it's not set up for the 12 pole. If not, I'll just write the check...
    Mercury 10,000rpm tach's.
    Houston, TX
    Quote Originally Posted by Dave Strong View Post
    Ha! Wish I NEEDED a 10K tach!
    Quote Originally Posted by rgsauger View Post
    They are a very accurate tach but getting hard to find. Autometer marine make good gauges.
  1. Any SW fl guys running up river tomorrow?
    By XstreamVking in forum General Boating Discussion
    Last Post: 10-08-2014, 08:19 PM
  2. Need advice from guys running nose cone
    By Jeb1971 in forum Props, Setup, and Rigging
    Last Post: 10-10-2007, 09:06 PM
  3. What props are you inline 6 guys running?
    By KG4 in forum Props, Setup, and Rigging
    Last Post: 08-09-2006, 11:20 AM
  4. How Do You Guys Running Warp Speeds Have Your Trim Set Up??
    By Instigator in forum Technical Discussion
    Last Post: 02-24-2003, 06:23 PM
