Results 1 to 6 of 6
    Mar 2020
    netherlands
    Mercury 115 2 stroke 2+2 high idling rpm
    My Merc 115 2 stroke 2+2 is idling very high, around 1700-1800 rpm, so shifting is a little tough on the gears. When i shift in gear rpm drops to 800 +- It runs like a dream, except when i want to do a hole shot, it needs some time to response to the throttle. Couple of seconds sometimes. But then rpm comes up and after that flies like a missile. Its only when i do a holeshot. If i build it up, or when i hit the throttle when im already on plane it works fine. Oh and also sometimes te engine holds back a little bit when on full throttle. Not much, but you can definitly feel it backing down. I guess those problems are unrelated.
    What could the issue be? I changed the plugs, changed fuel lines, cables, cleaned filters, checked sparks / bobines. I did not yet pull the plugs of the bottom 2 cylinders te see what happens on idle. I guess they are running along on idle. Also the levers are returning in there original positions when pulling back the throttle.
    when i pull the trigger arm forward (to the bow) rpm drops.
    Could it be that my acceleration pump is faulty? (It sticking open i dont know) or perhaps some bad reeds? I am facing a mystery here, any help is welcome!
    Mar 2020
    netherlands
    Any suggestions are welcome
    May 2014
    Livingston, Louisiana
    Many many possibilities. 1st thing I personally would start with looking for would be a vacuum leak from crank seals, intake and such. And of coarse link and sync/all linkages moving freely (carbs closing all the way/idle timing coming down to where it’s supposed to be.
    Pull the accelerator pump apart and look at the diaphragm. They are starting to get stiff with age, also make sure all the check valves are clean and working. The bleed and enrichment circuits are those motors are fussy.
    Dec 2003
    Check your "link and sync", make sure all carb butterfly's are closed at idle.
    Dec 2003
    Check all linkages to be sure none are sticking.
  1. 96 mercury 200 efi idling to high
    By Calvin1013 in forum Technical Discussion
    Last Post: 10-22-2018, 04:48 PM
  2. Merc 2.5 280 idling high
    By NeedlesRat in forum Technical Discussion
    Last Post: 06-30-2017, 09:42 PM
  3. 1997 Mercury 200HP Offshore Edition Idling Too High
    By MakoTom221 in forum Technical Discussion
    Last Post: 07-06-2011, 08:09 AM
  4. OMC Tech: Johnson 4 stroke Idling Erradic
    By bigboatin in forum Technical Discussion
    Last Post: 05-12-2010, 03:57 PM
  5. 300 X idling high
    By Tom Foley in forum Technical Discussion
    Last Post: 10-06-2007, 11:31 AM
