Results 1 to 4 of 4
    Houston, TX
    Breaking in rings on a 2.4 V200 chrome Merc
    Hi fellows. So I have read ALL KIND of stuff on here about breaking in motors and see 10-20 hours of varied RPM's and heavy oil and such as a common theme.
    If I only put in new rings on my stock Merc pistons in my chrome mota, does this long break-in apply again? (Would manually scuff the bores with green scotchbrite)
    thanks
    Aug 2005
    West Allis,Wisconsin
    Don't scuff bores per shop manual, Put in new rings, check bores for taper, vary speeds for 2 hours and then run it.
  3. Likes Dave Strong liked this post
    Unless a very low hour motor it probably needs more than just rings, would bet pistons are worn beyond spec. Skirts and ring lands.
  5. Likes WillySteve liked this post
    Houston, TX
    Fair points on wear. I'll check that. I need to do another compression check since I decarbed it
  1. Preping a chrome bore merc for new pistons and rings
    By carb a rator in forum Technical Discussion
    Last Post: 02-03-2020, 02:25 PM
  2. Mercury Tech: Chrome rings or steel?
    By speedinstream in forum Technical Discussion
    Last Post: 01-18-2010, 12:40 AM
  3. 260 rings can i use chrome rings
    By jgiroux in forum Technical Discussion
    Last Post: 07-02-2009, 09:54 AM
  4. What to do to prep a chrome bore for new rings?
    By pwerwagn in forum Technical Discussion
    Last Post: 06-13-2006, 07:36 AM
  5. Who can cut chrome rings to fit top pinned Merc Drag pistons?
    By O/B Dude in forum Technical Discussion
    Last Post: 10-08-2003, 09:52 AM
