Results 1 to 15 of 17
03-24-2020, 04:53 PM #15000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
03-24-2020, 05:36 PM #2
Its oil mixed with water. Hopefully your fuel pil and not gearcase oil
Mite be running a bit rich..
Seanj85 liked this post
03-24-2020, 05:40 PM #35000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
03-24-2020, 06:40 PM #4
un-burnt fuel mixin' with water.. could be idle timin'? dead or non firin' cylinder/cylinders... maybe?
03-24-2020, 08:40 PM #55000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
Any ideas on what to troubleshoot first?
03-24-2020, 09:18 PM #6
Does it have pulse fuel pump? They have a tendency to flood the cyl providing the pulse if diaphragm is bad , will pretty much pour raw fuel out of prop
XstreamVking liked this post
03-24-2020, 09:41 PM #75000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
03-25-2020, 06:33 AM #8
That's a diaphragm pump , if pump was bad prob run like crap or run out gas at wot ,but I had one wouldnt idle for nothin and raw fuel runnin out prop ,but run fine close to wot cause it could burn most of it off worth a look or rebuild pump is cheap , could be tps also, temp sensor, etc
03-25-2020, 06:57 AM #9Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Seems I remember a return hose with a screen filter in it that could cause a over fueling condition. Those old efi's are so tough you could pour fuel down the intake and they would still run.
03-25-2020, 07:01 AM #105000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
I will order parts and rebuild it. I will report back. Seems like a logical place to start.
03-25-2020, 07:01 AM #115000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
03-25-2020, 07:03 AM #12
Plz inspect b4 throwing $ at it , xstream pretty gud with 3.0 and other gud to ,
03-25-2020, 07:05 AM #135000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
03-25-2020, 07:09 AM #14
Depends how long been on there, if I'm not mistaken, u can split it and look at diaphragm without messin up gaskets ? I think haha
03-25-2020, 09:59 AM #15Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Look at a schematic on boats .net or some other and locate all the parts b4 opening. Might need another vst o-ring...They are spendy...
What is causing this rust?
By tony97gt in forum Technical DiscussionReplies: 75Last Post: 05-16-2014, 07:11 AM -
Prop causing vibrations?
By Mhall222 in forum General Boating DiscussionReplies: 5Last Post: 05-08-2010, 01:34 AM -
Mercury Tech: Whats causing my 150 merc to catch a pocket when I turn left???
By coreyh912 in forum Technical DiscussionReplies: 10Last Post: 07-23-2009, 08:50 PM -
What could be causing this?
By david laser86 in forum Technical DiscussionReplies: 9Last Post: 09-01-2007, 12:03 PM -
79 Merc 90hp causing a diagnosis headache...
By csdstudio in forum Technical DiscussionReplies: 1Last Post: 06-25-2007, 07:47 AM
