Results 1 to 10 of 10
    how to melt away 5200 adhesive without ripping glass
    around the 2:30 mark, he discovers something about melting away 5200 for easier removal ...
  2. Thanks powerabout thanked for this post
    7 Post(s)
    Video didn’t work.
    Ive destroyed everything assembled w/5200 that I tried to disassemble.
    Dide he set the transom on fire at the 2:30 mark?
    I never had a project that I could use heat on.
    Quote Originally Posted by noli View Post
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    he poured this liquid where the 5200 was, and it melted like butter but didn't hurt the fiberglass
  5. Thanks Instigator thanked for this post
    Likes Instigator liked this post
    7 Post(s)
    I’ve heard of this but not used it or talked to anyone that has.
    Ill try the video again.
    I tried acetone before w/no luck.
    Basically decided that anything strong enough to eat it would probably eat everything else too.
    Thanx for the tip!
    8 Post(s)
    I wonder what chemicals are in that tin?
    Mar 2009
    Saint Lucie Florida
  9. Likes Instigator liked this post
    Jul 2004
    houston,tx
    heat,,,,,softens the 5200
    a good heat gun to heat the part to absorb into the 5200 will soften it
    when able to get away a bit then most heat between part on the 5200
    just like heating to get stuck studd to pull out of mid,,,,,,
    just no flame from torch not to burn glass
    Jul 2012
    Lufkin, Texas
    Marine Formula by DeBond...
  12. Likes powerabout liked this post
  13. #9
    7 Post(s)
    Every instance I’ve needed to get rid of 5200 (in post above) you couldn’t use heat w/o damaging boat that 5200/part was glued to.
    Heat the 5200 between an O/B bracket and transom it’s bolted to w/o destroying the transom it’s glued to.
    Quote Originally Posted by johnmiffco View Post
    Jul 2004
    houston,tx
    some can heat without burning the part and some cannot,,,,,
    takes a lot of concentrated heat with a """heat gun"""" to burn the resin
    heat the part not the fiberglass as stated
    and stated no torch flame,,,,,,
  1. E-glass or S-glass and what weight cloth???
    By pcrussell50 in forum Fiberglass and Composites Discussion
    Last Post: 03-12-2010, 07:57 AM
  2. Ripping Acoustic Guitar
    By Racemore in forum The Scream And Fly Lounge
    Last Post: 12-08-2007, 08:46 PM
  3. phase one: ripping EVERYTHING OUT almost compleat (pics)
    By wing nut in forum General Boating Discussion
    Last Post: 07-09-2002, 12:03 AM
