Results 1 to 11 of 11
    Mar 2020
    ALCOA tn
    Help!! 1994 mercury xri 200
    i removed my auto Oiler and now the low oil alarm is on how do I stop it from sounding?
    Might be better in Tech
    Mar 2020
    ALCOA tn
    Quote Originally Posted by Mark75H View Post
    I can’t figure out how to post on different threads 🤔
    May 2001
    Ga
    Take small oil tank off motor , remove oil pump and metal gear , install plastic plug in its place , remove oil motion sensor and wires , remove oil warning module and tan and purple wires going to the two studs right under the solenoid . I usually test the temperature sensor . Key on , then ground the stud with the tan wire . It should sound the alarm .
  5. Likes Capt.Insane-o liked this post
    Mar 2020
    ALCOA tn
    I’m gonna try that tomorrow thanks in advance
    May 2001
    Ga
    I’m guessing it’s a Norris craft ?
    Mar 2020
    ALCOA tn
    Quote Originally Posted by half fast View Post
    Yes indeed
  9. #8
    Mar 2020
    ALCOA tn
    So the oil warning module, remove it and all the wires?
  10. #9
    May 2001
    Ga
    Yes . And I like em too
    Attached Thumbnails Attached Thumbnails FC0727CD-71DB-4697-9A1C-3890CFA71FFA.jpg
  11. #10
    Mar 2020
    ALCOA tn
    What size is yours? How fast will it go?
  12. #11
    May 2001
    Ga
    1993 1900 xlv , 200 merc efi , solid mounts , 26 trophy , runs high 70’s real fun to drive . Hf...
  1. Mercury 1994 2.0L 150
    By Glastron1987 in forum Technical Discussion
    Last Post: 04-24-2019, 08:38 PM
  2. Mercury 1994 200HP
    By mragu in forum Outboard Engines
    Last Post: 04-04-2019, 10:32 AM
  3. 1994 Mercury Pro Max rigging
    By Warrenroadie in forum Technical Discussion
    Last Post: 02-17-2017, 04:01 AM
  4. 1994 200hp mercury efi
    By Mak in forum Technical Discussion
    Last Post: 05-06-2016, 07:46 PM
  5. Need Some info on 1994 Mercury 200 xri
    By cheapbeater in forum Technical Discussion
    Last Post: 04-16-2009, 10:20 AM
