Results 31 to 45 of 59
  1. #31
    Sep 2017
    Ashland city tn
    I think u could buy a good used 3.0 for price of rebuild but wont b new , that boat really needs it, but a 2.5 will get the jib done just not as good
  2. #32
    Oct 2019
    Alabama
    Yea I love the boat. Just feel it’s under powered with the 150. Id settle with a 200 but would like to have 225. And if I’m measuring correctly, I actually need a XL shaft. This XR6 is a 20”
  3. #33
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Dewey-05 View Post
    No it shouldn't need a 25 shaft , I can jack my motor to the moon and never loose pressure but loose bow lift ,, I have low water pick up also I know a guy that got a 2.4 200 u can get cheap but its gonna need a sleeve and rebuild kit. But it's cheap, even tho it's a 2.4 , it would have more than xr6
  4. #34
    Oct 2019
    Alabama
    I measured from top of transom to the lowest part ... below the drain plug..and it was 28”
  5. #35
    Jul 2005
    AZ
    Have any pics...most likely 20" most are.
    Michael
    '84 Checkmate Convincor
  6. #36
    Oct 2019
    Alabama
    I don’t. I’ll try and get some in the morning
  7. #37
    Jul 2005
    AZ
    Are you going to install a low water pickup?
  8. #38
    Oct 2019
    Alabama
    Probably not seeing as how i don’t even know what that is lol. I’ll have to research it
  9. #39
    Jul 2005
    AZ
    It moves the water pick to the bottom of the point in the front of lower unit so you can raise lower unit higher and not loose water pressure..
    Easy enough to install, if you can do small body work you can do it just need to get instructions..
    Can explain, get you through it if you decide and need help
    Just make sure you do it the correct way
    Definitely worth it if you fish in shallow water too
    Michael
  10. #40
    Jul 2005
    AZ
  11. #41
    Sep 2017
    Ashland city tn
    I can measure mine to compare , it's the 18.5 , it has 8 in jackplate and needs 10 maybe 12 in , with 2.5 promax, to help with bow lift with over hub props , so u will definitely need set back Click image for larger version.
    Here a ****ty pic , but with 8 in plate it sits pretty level n water
  12. #42
    Oct 2019
    Alabama
    Shows invalid link but I can look it up and don’t worry... lol... I’ll definitely be back if I decide to install lol
  13. #43
    Oct 2019
    Alabama
    If that’s level.. then mine is really low in the water ... I’ll try to post pic if it’ll let me.. I keep getting an error message saying I need more than 3 words to reply,, even when I try to reply with a quote. I’ll try to do a pic.
  14. #44
    Jul 2005
    AZ
    Should show now... Not sure what's up but loading pics and posting lately has been a pain in the ass
    Michael
  15. #45
    Oct 2019
    Alabama
