Results 1 to 7 of 7
Thread: Vst hose plumbing???
02-25-2020, 08:27 PM #1
On my Promax the hose on TOP of the vst tank gos to this brass nipple on the intake. I have it connected to the BOTTOM fitting with the hole. When I squeeze the primer bulb there is a bit of gas that dribbles out of the hole in the brass fitting. Is this the correct location for the top of the vst tank?.
The other hose is connected to the fuel pressure regulater..
Vst system has been completly cleaned.
02-26-2020, 12:30 PM #2
You have the hoses correct, float and needle and seat should prevent fuel from coming out the fitting on top the VST. Float might be a tad high or needle leaking some.
02-26-2020, 02:24 PM #3
Thank you
03-04-2020, 01:27 PM #4
Needle had a tad bit of crusty on it. All cleaned and works great now... but still think a gas warp under the cowl is a bad idea. Wouldn't know it till without the cover off or catches fire.
03-05-2020, 07:11 AM #5
what 'bout all tha other stuff "under tha cowl" tha could spring a leak?....
03-05-2020, 07:15 AM #6
Could. Key word "could" this weep hole is made and put there to leak
03-05-2020, 07:17 AM #7
woulda, coulda, shoulda.. not much difference.............
Where to buy billet rigging hose flange for larger optimax hose
By aggiestckl in forum General Boating DiscussionReplies: 9Last Post: 05-03-2016, 11:15 PM -
need plumbing help
By nerve damage in forum Jet Boats, V-Drives and Stern DrivesReplies: 2Last Post: 02-27-2010, 11:19 PM -
Mad EFI Plumbing
By Charger200 in forum Technical DiscussionReplies: 3Last Post: 12-31-2009, 08:08 PM -
Here we go again with the plumbing!!!!!!
By Talon2.5 in forum General Boating DiscussionReplies: 39Last Post: 06-14-2002, 07:23 AM
