Results 1 to 3 of 3
    Nov 2013
    palatka fl
    bleed line check valves
    guys what is best way to remove these check valves i have found 3 on my motor that tested bad by vacume test do they push in and pull out .1993 merc 2.5 200 hp v6 thanks
    minocqua, wis
    Heat around fitting to help expand block a little grab with vise grip and twist slowly pulling out take your time
    Nov 2013
    palatka fl
    check valves
    Quote Originally Posted by eli View Post
    thanks eli i found new ones at pro marine if any one needs them.
  1. check valves for bleed lines
    By eli in forum Technical Discussion
    Last Post: 01-26-2018, 09:22 PM
  2. Mercury Tech: 2.0L bleed check valves
    By pcrussell50 in forum Technical Discussion
    Last Post: 01-08-2017, 03:47 PM
  3. Mercury Tech: Bleed Check Valves/96 250 EFI
    By Liberator*21 in forum Technical Discussion
    Last Post: 04-24-2010, 04:06 PM
  4. bleed line check valves
    By dadgumit in forum Technical Discussion
    Last Post: 01-31-2009, 09:27 AM
  5. 2.4L Bleed Hose Check Valves
    By Roger Steele in forum Technical Discussion
    Last Post: 11-25-2004, 02:33 PM
