Results 1 to 3 of 3
Thread: Re-gearing a CR sportmaster 3.0
02-24-2020, 01:24 PM #1Junior Member
- Oct 2017
- Missouri
- 27
- 9
Re-gearing a Counter rotate Sportmaster 3.0 What parts do I need? Does the forward gear come with the pinion gear? What other parts should I replace. Going from a 1.75 to a 1.62 Why, it had mismatched gear ratios when I bought it.
Thanks
02-24-2020, 01:44 PM #2
full gear set, shims,tab washer,pinion nut and washer and all the tools to set it up properly.
03-04-2020, 06:23 PM #3
Sportmaster gearing
By KIRCHNER in forum Technical DiscussionReplies: 5Last Post: 12-10-2018, 10:17 AM -
2:00-1 VS 1:87-1 Sportmaster Gearing
By MUFC777 in forum Technical DiscussionReplies: 4Last Post: 04-11-2011, 02:20 AM -
gearing
By berdes in forum Technical DiscussionReplies: 7Last Post: 11-07-2009, 08:06 AM -
Gearing
By berdes in forum Technical DiscussionReplies: 0Last Post: 11-06-2009, 02:30 PM -
gearing
By shane v in forum Props, Setup, and RiggingReplies: 3Last Post: 03-01-2004, 03:36 PM
