Results 1 to 15 of 19
Thread: Merc 2.5 carb questions?
02-23-2020, 06:37 PM #1
Building a 2.5 200FF block. Porting it between 225-245hp block. The past season I ran these carbs with .68 main jets. Since the engine is going to require more fuel and air I was curious if these carbs will work fine if I re-jet them or should I go to a larger style carb maybe a wh20 or stick with the wmh? Thanks guys
16ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft sleekcraft modvp
18ft action hst drag
18ft accelerator drag
21ft redline
18ft vking yt
20ft Allison grandsport
20ft laser 420
18ft X-Stream Vking
24ft banana
02-23-2020, 06:57 PM #2
Stick with those....leave them jetted the way you have them. 68’s will support plenty of hp....that’s stock jetting on a 245.
'95 STV "The Blue Goose"
02-23-2020, 09:29 PM #3
Have 2 ff blocks ported 260 and run same carb off my 245,s 68 main ,60 idle no back draft , think 50 off idle ,
wogi liked this post
02-24-2020, 10:49 AM #4
Are you running a 245 cross drilled seven peddle intake? what is your elevation above sea level? Eli and I are at roughly 750 ft
1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
02-24-2020, 11:20 AM #5
I have not ran it yet, but I have a stock 245 which has a crossdrilled intake and I got it with WH31 carbs with 94 main jets. I am swapping to a WH20 carbs and will see where the 94 mains put me at. I am guessing they will be rich but will find out in a few months once the water is not so hard (Frozen)!
1973 Viper - sold
1978 Viking - sold
1995 XB02
02-24-2020, 03:50 PM #6
Wh 20 and the ones you have the venturi #84 are 1.315 ,i did try briefly wmh 47,s off 3 liter 1.465 venturi # 94 worked well if i was racing all the time but gas milage wasnt as good and i like to cruise
02-24-2020, 05:43 PM #7
02-24-2020, 06:21 PM #8
I would say so it will run like the choke is on
02-25-2020, 09:01 AM #9
I ran .72 breaking and .68 on all my 245’s. Actually kept the .72’s on my Howard after break in due to today’s fuel.
02-25-2020, 09:53 AM #10
According to the factory service manuel, 72 are break in jets for a 245
02-25-2020, 10:11 AM #11
yes, 72 and 68 are the WHM carbs, but with the WH series I am guessing I will end up somewhere in the ballpark of mains for a carb BP. I think mid to upper 80's. I am not worried about fuel mileage, mainly will be setting up for 800 foot drags and the occasional run on the weekend, which will most likely call for a main jet change.
But run the WHM Superboat and let us know how ya like them.Last edited by rjdubiel; 02-25-2020 at 10:15 AM.
1973 Viper - sold
1978 Viking - sold
1995 XB02
02-25-2020, 10:45 AM #12
If you’re going to run a WHM with jets in the 80’s you’re gunna be awfully disappointed. Remember, 2.4 porting is nowhere near as efficient as 2.5 porting. It’s not the extra 100cc’s of displacement that took mercury race V6’s from 2.4 245hp (if you were lucky) to 2.5 worked drags making 350+. It was the more efficient port design. This, by nature will use less fuel. Not to mention 80 jet sizes were needed for a completely different carb type (WH).
I ran a ‘05 280 on carbs for awhile.....stock WHM 21’s (200 carb)....jetted at a 64.....and turned 8000+ rpm with a 33
02-25-2020, 11:24 AM #13
The original question is should he run WHM carbs or WH carbs with his mod FF block. My guess on my 2.5 245 running WH carbs is i will end up in the 80's on the main jets. If running WHM carbs I am thinking everyone is onboard with the mid 60's to low 70's mains. Thats all, no one is running 80's mains in the 3 circuit WHM carbs.
1973 Viper - sold
1978 Viking - sold
1995 XB02
02-25-2020, 11:47 AM #14
Early 245hp with pumper carbs ran .072 mains, later non pumper style ran .068.
tux974 liked this post
02-25-2020, 05:29 PM #15
carb merc 2.4 200 questions
By platinumracer05 in forum Technical DiscussionReplies: 11Last Post: 04-11-2011, 01:55 AM -
Mercury Tech: 85 Merc 200 Carb Jet Questions
By RMan in forum Technical DiscussionReplies: 8Last Post: 11-16-2008, 02:32 PM -
OMC carb questions
By Action Dave in forum Technical DiscussionReplies: 10Last Post: 02-21-2008, 03:00 AM -
Older 20 HP Merc Questions (Exhaust & Carb)
By KeithS in forum Technical DiscussionReplies: 4Last Post: 06-25-2007, 03:09 PM -
Inline Merc Gurus. Carb questions...
By Georgia Boy in forum Technical DiscussionReplies: 0Last Post: 08-16-2004, 03:15 PM
