Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
    TX......somewhere?
    have ya tweaked on your set-up?.. pretty heavy boat for a 2.0 motor..
  2. #17
    Oct 2017
    Jackson Ga
    Haven’t really done much at all.. played with a few props. I’m just now starting to play with the motor. Just not sure what all I can Do.
  3. #18
    TX......somewhere?
    ya might get on one of tha other boards that has a "stratos" forum and see if any of 'em have run anything like yours.. BBC may have one.. I personally don't have a lotta experience with that hull and "production" 2.0 motor.. jus don't wanna lead ya in tha wrong direction.....
  4. #19
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by Coon Krazy View Post
    My plan was to have them cut 20 thousands... debating on using stock gaskets or .75s
    .O2O isnt gonna do diddly squat.
  5. #20
    Sep 2017
    Ashland city tn
    Ya need sumbody to cc ur heads 28 or 30cc (I think) but the compression guage may b little tricky with the reliefs, if the boat and motor was mine , I'd put set wh46 carbs on it and rejet em and it will pick up 3 or 400rpm on top and pick up hole shot to. I've done it to 2 motors (150 2.0) really helped,, not real sure if u got horizontal or vertical front (intake) u want a horizontal tho , and have heads cut , but jetting u will have to do and do it rite or all that work down the drain if not done rite and loose ur motor. Just b careful,, I remember when I knew just enuff to screw schit . Lol. It's not hard to do haha
  6. #21
    Mar 2010
    houston, tx
    That’s a heavy boat.
    I know the 2.5 blocked 2.0’s are different from
    the old “real” 2.0’s but they benefit being on a lighter boat.
    You could do all this and not be where you would if you just sold your 135 2.0 and put a 150 2.5 powerhead on.
    Just pull and sell the powerhead , or compete motors. Whatever.
    Would be my choice if it were me.
  1. Mercury Tech: 2.4L BP Heads Question
    By Tango in forum Technical Discussion
    Last Post: 09-04-2015, 07:46 AM
  2. Question Regarding Heads
    By trashy in forum Technical Discussion
    Last Post: 10-22-2007, 10:11 AM
  3. Question about Baker Heads????
    By BenKeith in forum Technical Discussion
    Last Post: 03-18-2004, 10:26 PM
  4. Question about these heads
    By 83Enchanter in forum Technical Discussion
    Last Post: 05-08-2002, 07:06 AM
  5. Question On Heads
    By Carter Powell in forum Technical Discussion
    Last Post: 02-22-2002, 02:11 AM
