Results 1 to 15 of 21
    Oct 2017
    Jackson Ga
    Question about 2.0 heads
    I’m being told my 135 Merc is a 2.0. I was Searching for a set of performance heads for it.. all the heads I’m finding doesn’t have the holes for the dial pins. My heads have dial pin holes. How would I find Heads for my
    motor?
    Aug 2006
    GA
    I might have a Set.
    Oct 2017
    Jackson Ga
    Is this normal? 2.0s don’t have dial pins? Or is it a certain HP?
    TX......somewhere?
    ok.. '91 up 2.0/2.4/2.5 all have dowel pins.. what kinda comp do you have now with stock heads?
    do you have an oem manual?.. if not send me an email addy and i'll send ya pdf that covers justa bout all '92 up 2.0/2.5's....
    Oct 2017
    Jackson Ga
    110 on all 6. I pulled Them tonight to have the cut.. just weighing my options.
    Oct 2017
    Jackson Ga
    My plan was to have them cut 20 thousands... debating on using stock gaskets or .75s
    TX......somewhere?
    don't remember 2.0? does it have relief slots?
    Oct 2017
    Jackson Ga
    My carbs are WMH 12Bs is there a better carb I can Find to get more performance?
    Oct 2017
    Jackson Ga
    How would I know? Where would they be?
    TX......somewhere?
    slight "notch" at top of cylinder on exhaust side.. maybe 1/2" wide and 1/2" tall?
    they are referred to as "exhaust relief slots"..
    Oct 2017
    Jackson Ga
  12. #12
    TX......somewhere?
    yes they do.. see tha little notch in tha sleeve?.. that would make crankin' compression ya see justa a tad low but tolerable..
  13. #13
    Oct 2017
    Jackson Ga
    I’m guessing that’s what your talking about?
  14. #14
    Oct 2017
    Jackson Ga
    Well my gaskets was history.. they looked pretty bad. I guess I’ll cut the heads and put new gaskets on.. that should help my compression a little.
  15. #15
    Oct 2017
    Jackson Ga
    The motor runs awesome.. pushes a 18.5 stratos 55 mph.. not bad at all for what it is. I just Want a little more.. 3-4 mph I’d be happy
  1. Mercury Tech: 2.4L BP Heads Question
    By Tango in forum Technical Discussion
    Last Post: 09-04-2015, 07:46 AM
  2. Question Regarding Heads
    By trashy in forum Technical Discussion
    Last Post: 10-22-2007, 10:11 AM
  3. Question about Baker Heads????
    By BenKeith in forum Technical Discussion
    Last Post: 03-18-2004, 10:26 PM
  4. Question about these heads
    By 83Enchanter in forum Technical Discussion
    Last Post: 05-08-2002, 07:06 AM
  5. Question On Heads
    By Carter Powell in forum Technical Discussion
    Last Post: 02-22-2002, 02:11 AM
