Results 16 to 21 of 21
Thread: Question about 2.0 heads
02-20-2020, 09:44 PM #16
have ya tweaked on your set-up?.. pretty heavy boat for a 2.0 motor..
02-20-2020, 09:45 PM #17Member
- Oct 2017
- Jackson Ga
- 31
Haven’t really done much at all.. played with a few props. I’m just now starting to play with the motor. Just not sure what all I can Do.
02-20-2020, 09:55 PM #18
ya might get on one of tha other boards that has a "stratos" forum and see if any of 'em have run anything like yours.. BBC may have one.. I personally don't have a lotta experience with that hull and "production" 2.0 motor.. jus don't wanna lead ya in tha wrong direction.....
02-20-2020, 10:08 PM #196000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
02-21-2020, 06:50 AM #20
Ya need sumbody to cc ur heads 28 or 30cc (I think) but the compression guage may b little tricky with the reliefs, if the boat and motor was mine , I'd put set wh46 carbs on it and rejet em and it will pick up 3 or 400rpm on top and pick up hole shot to. I've done it to 2 motors (150 2.0) really helped,, not real sure if u got horizontal or vertical front (intake) u want a horizontal tho , and have heads cut , but jetting u will have to do and do it rite or all that work down the drain if not done rite and loose ur motor. Just b careful,, I remember when I knew just enuff to screw schit . Lol. It's not hard to do haha
02-22-2020, 03:14 PM #21
That’s a heavy boat.
I know the 2.5 blocked 2.0’s are different from
the old “real” 2.0’s but they benefit being on a lighter boat.
You could do all this and not be where you would if you just sold your 135 2.0 and put a 150 2.5 powerhead on.
Just pull and sell the powerhead , or compete motors. Whatever.
Would be my choice if it were me.
Mercury Tech: 2.4L BP Heads Question
By Tango in forum Technical DiscussionReplies: 6Last Post: 09-04-2015, 07:46 AM -
Question Regarding Heads
By trashy in forum Technical DiscussionReplies: 0Last Post: 10-22-2007, 10:11 AM -
Question about Baker Heads????
By BenKeith in forum Technical DiscussionReplies: 4Last Post: 03-18-2004, 10:26 PM -
Question about these heads
By 83Enchanter in forum Technical DiscussionReplies: 3Last Post: 05-08-2002, 07:06 AM -
Question On Heads
By Carter Powell in forum Technical DiscussionReplies: 0Last Post: 02-22-2002, 02:11 AM
