Results 1 to 15 of 17
Thread: Seastar ram rocking
02-20-2020, 08:36 PM #16000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
Seastar ram rocking
I thought i had air in system, but thats not the case. i watched the ram ends, the aluminum ears are rocking one end rises, the other end kicks down. that slight movement allows play and at 80, not liking it. cant understand why its acting like a torsion bar. should i tighten the tilt tube? also how tight should the pivit bolt be? looks like a nylon bushing of sort, that also rocks slightly?
02-22-2020, 08:36 PM #2
I switched to the Seastar Tournament Pro cylinder with the keyed shaft ends that stops the twisting. Mine is rock solid now.
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
KIRCHNER thanked for this postbaja200merk liked this post
02-23-2020, 11:18 AM #3
Loosen the knurled adjusting nut on the tilt tube and make sure the ny-lock nuts on the pin going through the tilt tube and on the cylinder rod are tight. Then tighten the knurled nut back up. Don't forget to tighten the set screw in the knurled nut when you are done.
Euroski liked this post
02-23-2020, 01:10 PM #46000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
The adjusting collar is on starboard side with set screw?? it seems something is wearing,from trimming up n down. ive tightened those nuts before and the movement slowly comes back. are the aluminum ears supposed to remain a fixed distance apart, matching the ram rod? when i tighten the tilt nuts if the ears move closer or wider, ram rod length is fixed , all connections need to be a 90'. i think im missing a shim somewhere??
02-23-2020, 01:47 PM #5"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
02-23-2020, 03:42 PM #6
The EARS stay tight on the ROD. The EARS should tilt with the ROD. The rod and ears should be as one.
02-23-2020, 07:48 PM #76000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
F i thinking correct ears are tight on the rod, but the rod will still swivel as 1 unit? not tight against engine tube? what keeps the ears from squeezeing against engine tube, stopping the swivel motion? brain storm the rod has a flange so ears can only move in so far and i take up slack with spacers? yes? if so i have too many spacers the more it tighten, the more they wear... does that make sense? that has to be why im getting the play every 5-6 run hours of run time.
02-23-2020, 07:55 PM #8
The knurled adjusting nut takes up the slack...it does not need to be super tight, just tight enough to stop the slop. The rod that goes through the tilt tub should pivot inside the tilt tube. If it is seized in the tilt tube, the ears will become loose from the nut backing off every time you trim or tilt the motor. Grease is the key to keep everything working the way it should.
02-23-2020, 07:57 PM #9
to answer your previous question, with the knurled nut screwd all the way onto the tilt tube, you should be able to tighten all the rod nuts at the ears and still have play in the steering, then take up the play by adjusting the knurled nut out.
02-24-2020, 09:54 AM #106000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
ive got it now, going today and see whats up. thanks i understand now what to do..
02-25-2020, 04:02 PM #11
02-28-2020, 05:29 PM #126000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
Well i worked all morning and acomplished nothing. the rocking is the bushing tiller bolt. is must have a shoulder, i backed off lock not bottom side, but bolt is tight, ican see a gap if i pull on the cav plate back and forth. looks like some material is being squeezed out of joint? is that coupling a seastar part? cant really see it. pan is right on top. im ready to trash the whole POS! Cant get my fingers in there, an openend barely 9/16. What should i do? real bummer.
02-29-2020, 02:23 PM #13
I agree that the specialty tiller bolt is almost impossible to get to. The large bushing/bearing/washer comes with the new keyed end tournament cylinder, along with a new traceable hardware tiller bolt. I got a real-deal on my new cylinder from a San Diego Go2marine.
Allison GSE 300XS
03-01-2020, 11:22 AM #146000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
i wassearching seastar parts, and unbelievably i found a company 5 min away, in an industrial park, that rebuilds, reconds all power tilts, trims, pistons everything seastar. 5star marine. ill see whats up with that bushing from them. heck, ill tow it over there, maybe find a final fix. there in port richey, fl. when i told tech boat runs about 80 he said buy a complete new system. i need a # ha5820 tiller bushing kit.????
03-02-2020, 09:22 PM #15
Anything over 60MPH, you should be using the Pro Series steering......
Hydraullic Jack Plate and Seastar/ Seastar Pro (Merc 225)
By strat250 in forum Parts WantedReplies: 2Last Post: 03-23-2019, 12:20 AM -
Need a Seastar Pro or Seastar Helm only
By mragu in forum Parts WantedReplies: 2Last Post: 05-18-2016, 09:41 PM -
Seastar tilt helm and Seastar front mount ram
By 87starflite in forum Misc. Parts and AccessoriesReplies: 2Last Post: 04-16-2014, 11:31 AM -
Horrible rocking with new engine/prop setup??
By Mhall222 in forum General Boating DiscussionReplies: 26Last Post: 03-20-2010, 03:25 PM -
leakdown test and piston rocking
By stoker2001 in forum Technical DiscussionReplies: 5Last Post: 03-30-2009, 05:18 PM
