Results 16 to 30 of 59
02-26-2020, 10:47 AM #16
Thats the VST, fuel pump is in there at the ft of the unit.
02-26-2020, 12:50 PM #175000 RPM
- Oct 2016
- Northern California
- 144
- 7
What does VST stand for, Vapor Separator Tank, or something along those lines? Anyone have experience testing or R&R'ing one of these?
1998 Viper Coral 201
1998 Mercury Promax 300 with Sportmaster
02-26-2020, 02:21 PM #18
Not sure about 3.0L but 2.5 has a pressure port to check regulated press. If you take it apart you will need a new o-ring to seal the top, they enlarge when removed and will not fit.
02-26-2020, 04:46 PM #195000 RPM
- Oct 2016
- 144
- 7
Yes, I see a Schrader valve on one of the ports, so it must be the same. When you say an o-ring, are you talking about a seal for the entire top of the tank, or do you mean where the schrader valve inserts on the top of the tank?
02-26-2020, 04:51 PM #20
Seal for the top of the VST. Sit down when you price it.
02-26-2020, 05:25 PM #215000 RPM
- Oct 2016
- 144
- 7
Are you talking about this part number? GASKET (#98-8M6002520)
02-27-2020, 03:06 PM #22
02-29-2020, 11:54 PM #235000 RPM
- Oct 2016
- 144
- 7
I finally got some time to eyeball the fuel lines, and can see there is new grey hose before and after the primer bulb. This must be what a shop installed when they replaced my bulb and some hose a few years ago.
The other day I spoke to the mechanic who rebuilt my lower end a couple of years ago. Like what you guys have already mentioned, he said there's a big problem with the new style fuel hose. When I told him I had some grey hose, he said that's the worst hose. He said he's been seeing two year old boats where their hoses are collapsing. He also said that even though I have fuel in my filter, it doesn't mean anything, and that that hose could indeed be my problem, and said that would be absolutely what he would look at first, just like you guys said.
There are some zip ties holding some hoses on, but where the grey hose connects, there some of these clamps pictured in the graphic below. Can someone please tell me how to remove this clamp? There appears to be a little tab that fits into a slot, and is bent down, in what appears to be a position so it can't slip back through the slot. Am I supposed to bend that little tab and somehow maneuver that tab back out of the slot? And, once I get it off, will I be able to put it back on, or should I use zip ties, or hose clamps, or...?
Also, if this ends up being my problem, or I want to test with a gas can and a different hose and bulb altogether, where do I get hose that doesn't have that inner wall like the new hose does?
03-01-2020, 11:17 AM #24
Those clamps are one use only and need the correct tool to install.
03-01-2020, 11:37 AM #255000 RPM
- Oct 2016
- 144
- 7
How do you get them off, and what can I use in their place, if anything?
03-01-2020, 11:39 AM #265000 RPM
- Oct 2016
- 144
- 7
And, can I use regular fuel line from an auto parts store, if I find a problem with that Grey line?
03-01-2020, 03:19 PM #275000 RPM
- Oct 2016
- 144
- 7
OK, spent the time necessary to troubleshoot. First thing I did was have someone turn the key to the ON position to see if I even hear the fuel pump in the VST. Nothing, no sound at all. Next, I hooked a multi-meter to the positive and negative terminals of the VST pump. Good continuity. Switched multi-meter to 20v setting, and turned key. Saw 12.3 volts, but heard nothing. Obviously the pump is not working. Went onto Crowley Marine site, and it says fuel pump is Part# 809088T and it's $769! Is that for real? even worse, it's not longer available. Anyone have any thoughts for me now?
03-01-2020, 04:14 PM #285000 RPM
- Oct 2016
- 144
- 7
Dave, thanks for pointing me to that o-ring seal number. I just ordered one, and also found a pump for the VST, which I just ordered. Now, all I need to do is find those clamps and the tool for it.
03-01-2020, 07:50 PM #29
I replaced the one-time clamps with some Aviation spec-grade clamps from West Marine. They are not cheap but work well.
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
03-01-2020, 08:36 PM #305000 RPM
- Oct 2016
- 144
- 7
OK, I'll check them out. I don't care how much they cost, as I only need a few. I wish I knew what sizes I need. I have two hoses with right angle bends coming from VST to brass housing with Schrader valve on it, which I assume or high pressure fuel hoses. They are stamped with 7.94mm. There is another hose of a similar size connected to a brass fitting at the back of the VST that has what looks like a special type of black zip tie. Then, underneath there is a tiny clear oil hose that also has that special zip tie, but it's tiny!
ISO 250 EFI Intake/Fuel ECU and 300 Promax Ignition ECU for 1998 3.0L 225 EFI
By xringmaster in forum Misc. Parts and AccessoriesReplies: 18Last Post: 01-28-2020, 07:11 AM -
2002 mercury 300x promax fuel delivery
By robalo24 in forum Technical DiscussionReplies: 3Last Post: 05-30-2016, 07:43 PM -
Fuel delivery issue causing me grief
By pointer in forum Technical DiscussionReplies: 4Last Post: 09-07-2014, 05:29 PM -
Pro Max fuel pump issue 1998 225 EFI.
By Enticer1 in forum Technical DiscussionReplies: 4Last Post: 03-08-2010, 09:12 PM
