Results 1 to 8 of 8
Thread: 26 Bravo 1
    Mar 2017
    Miami, FL
    26 Bravo 1
    26 Pitch Bravo I.
    Prop is in good shape. But I am not saying it is perfect. It could use a good polish if you want it to look better.
    Hub Included
    $300 Shipped to your door
    Jun 2019
    Australia
    Bravo 26p prop for sale
    Radiant,
    Is this RH and is it still for sale?
    Quote Originally Posted by Radiant View Post
    26 Pitch Bravo I.
    Hub Included
    Mar 2017
    Miami, FL
    Quote Originally Posted by Stuart grant View Post
    Radiant,
    Yes it is RH and still available
    Jun 2019
    Australia
    I have an xr sportmaster lower with 1.5 gearing. Do you know if your hub will suit?
    if not i assume it can be changed to suit?
    Mar 2017
    Miami, FL
    Yes the hub can be changed. But this hub may work for you, not really familiar with your lower.
    Jun 2019
    Australia
    ok, i’ll count the number of splines on my shaft and also measure diameter and compare with yours. Are you able to do the same please?
    Mar 2017
    Miami, FL
    I can, if you currently have a mercury prop with a removable hub that works on your lower, this prop will accept that hub. This hub currently in it is for the smaller diameter prop shafts.
    Jul 2018
    Staunton, Va
    Is this prop still available? square hub?
  1. BRAVO I FS 15.25 x 31 RH
    By hydroo in forum Propellers
    Last Post: 09-03-2019, 07:04 PM
  2. WTB 22 Bravo
    By FlatsFury in forum Propellers Wanted
    Last Post: 04-17-2018, 12:54 PM
  3. iSO bravo 1 26 p
    By Li bay rat in forum Propellers
    Last Post: 02-27-2017, 01:21 PM
  4. bravo 1 vs bravo xs
    By ultrafast in forum Props, Setup, and Rigging
    Last Post: 07-20-2016, 01:58 PM
