Results 1 to 11 of 11
    Apr 2018
    Henderson
    1 Pc or 2pc Adapter plate for 225 Promax?
    Just putting together My new (to me) setup, I have 15" mid/ single ram clamp that came with a 1 pc adapter and I have the 2pc adapter that came on my Promax that I blew up last season. Which one should I use? I've heard It's a nightmare trying to get cooling right with 1PC so I'm leaning to using the 2pc. Thoughts? any input is appreciated, thanks!
    Buy four of these..19-815784 stick them in the holes in your pan, run your t stats and poppit like a boss.
  3. Thanks RiverJunkie702 thanked for this post
    Feb 2011
    HUDSON, FLORIDA
    It took me mths to make the same choice. 15 mid, single ram, i went with the 2 pc, didnt want any heating/cooling issues. the 1pc may be stronger but in not ocean racin or need awing plate. the 2pc cant go wrong of course use the short tuner. i had to drill the 3 rear holes in plate 7/16 to match 15 can. 2pc uses 3 3/8'' my 15 can tapped for 7/16-16x
  5. Thanks RiverJunkie702 thanked for this post
    Apr 2018
    Henderson
    Thanks guys, also anyone happen to know the thread size for the hydraulic lines to the single ram clamp? Near as I can tell measuring inside female threads on the Ram it's .390 so guessing SAE 7/16-20, can anyone confirm this?
    Apr 2018
    Henderson
    Not quite following you there Capt. Are you saying run the 2 pc or the 1pc?
    One piece
  10. Likes Capt.Insane-o liked this post
    Jul 2004
    Connecticut
    Quote Originally Posted by RiverJunkie702 View Post
    Are you in Vegas? What is the high/low of water temps where you boat? It all starts with the range of temps.
    Apr 2018
    Henderson
    Yes I'm in Vegas,
    The Mirage, which this motor is going on, I usually only run on the river. Its 50 to 65 degree water temps, depending on what part of the river your on. Lake Mead on the other hand middle summer is like 80 -85 degrees feels like 90. but I try not to run this Hull on the Lake, test hits only because it's 5 min from the house.
    Winnipeg
    can you elaborate on this. I may put a 15" 200 promax together, thanks
    Allison XB02, 22ft Tritoon 225 4 stroke, two seadoo sparks
    Past rides 2001 STV EURO, Allison Grandsport, STV RiverRocket, STV Euro, STV ProComp, Hydrostream V-King
    RIP RPM RACING
    RIP GTS1
  14. #11
    Mar 2010
    houston, tx
    Could try to find an original 15” one piece promax adapter.
    Ive ran both one piece 280 and early 260 on my 15” promax and also 2 piece promax plates.
    I wanted to try my once piece Bridgeport plate on it but sold it.
    All have their pluses and minuses
  1. 225 promax with one piece adapter plate
    By Go Time in forum Technical Discussion
    Last Post: 07-20-2022, 02:53 PM
