Results 1 to 5 of 5
Thread: Sportmaster 20" driveshaft
02-15-2020, 06:55 PM #15000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
I'm looking for a driveshaft that is in good shape. Mine is all pitted and tore up around the water pump area.
02-16-2020, 01:09 AM #25000 RPM
- Aug 2006
- virginia
- 666
- 39
- 65
- 282
- 732
02-16-2020, 09:43 AM #3
where do you get this speedy sleeve
02-16-2020, 04:42 PM #45000 RPM
- Aug 2006
- virginia
- 666
- 39
- 65
- 282
- 732
your bearing seal shop, online, many manufacturers..drive shaft is .875 dia. So that's your size. See if you can get 1/2 lg.install with loctite green #648 retaining compound to fill any pits under the sleeve. youll have to make sleeves to drive it down over the shaft pinpointing where the seals ride, then remove the serated mushroom tab at the bottom.
02-16-2020, 08:26 PM #5
Here's what ya need
Wanted: 25" or 30" 2.5 driveshaft and 1.87 RH pinion/forward set for CLE/Sportmaster
By STV_Keith in forum Parts WantedReplies: 3Last Post: 05-05-2014, 12:18 PM
