Results 1 to 5 of 5
    Apr 2017
    Holland,MI
    Sportmaster 20" driveshaft
    I'm looking for a driveshaft that is in good shape. Mine is all pitted and tore up around the water pump area.
    Aug 2006
    virginia
    install a speedy sleeve on it and ride.
    Apr 2009
    pompano bch fl.
    where do you get this speedy sleeve
    Aug 2006
    virginia
    your bearing seal shop, online, many manufacturers..drive shaft is .875 dia. So that's your size. See if you can get 1/2 lg.install with loctite green #648 retaining compound to fill any pits under the sleeve. youll have to make sleeves to drive it down over the shaft pinpointing where the seals ride, then remove the serated mushroom tab at the bottom.
    Here's what ya need
  1. Replies: 3
    Last Post: 05-05-2014, 12:18 PM
