Results 16 to 30 of 33
Thread: What model merc do i have?
02-13-2020, 03:39 PM #16
item 21 is a "one piece adapter".. its later model but almost same as earlier... hi performance part.
https://www.crowleymarine.com/mercury-outboard/parts/2095_150.cfm?mdl=28KEQB
item 30 in this drawing is half of 2 piece... production motor parts
https://www.mercruiserparts.com/bam/subassembly/28630/579/160
item 27 in this drawing is second piece of adapter.. when combined referred to as a 2 piece adapter plate.
https://www.mercruiserparts.com/bam/subassembly/28630/579/220
02-13-2020, 03:40 PM #17
linky didn't work.. you will need to copy n paste addresses'...…………..
02-13-2020, 03:53 PM #18
if its a two piece it needs poppet and t-stats.. at least 3/8" hole (no larger) washers in stats place.. water discjarge needs ta be slowed down to do its job of removing heat... "no stats" can cause an over heat problem...
picture of plater under bottom cowl pan??
02-13-2020, 04:11 PM #19Junior Member
- Feb 2020
- Phoenix AZ
- 11
QUOTE=tlwjkw;3188593]if its a two piece it needs poppet and t-stats.. at least 3/8" hole (no larger) washers in stats place.. water discjarge needs ta be slowed down to do its job of removing heat... "no stats" can cause an over heat problem...
picture of plater under bottom cowl pan??[/QUOTE]
This is the only pic i have right now. If this ist what your looking for i can get more pic when i het home. I would also like to add i have owed this boat going on 3 yrs and just now it started this overheat issue. If that helps paint a picture
02-13-2020, 04:20 PM #20Junior Member
- Feb 2020
- Phoenix AZ
- 11
02-13-2020, 04:25 PM #21
looks like it started life as a factory "hot rod".. popped tha original power head and replaced with production 2.4.. won't need stats or poppet.. would add restrictor washers with 1/8" hole.. blank cover over poppet hole.. replace complete water pump (cle gear case)..
is there another number ona a tag on tha clamp saddle?
02-13-2020, 04:39 PM #22
washer part number..
12-47533 1
water pump "kit" part number
46-42579A4
02-13-2020, 04:39 PM #23Junior Member
- Feb 2020
- Phoenix AZ
- 11
02-13-2020, 04:43 PM #24
not ta fret!.. 'nough knowledgeable folks on here ta get ya thru most situations.. jus ask.. us old folks are bored anyway since we don't do it anymore.
TylerP, W2F a V-King liked this post
02-13-2020, 04:47 PM #25
I agree. U have no issues really with a frankinmerc, tlw, and others know these things with eyes closed. U gotta a question just ask. Sum of best runners frankinmerc, that's what I run neway, frankinmerc =poor man hot rod or bored haha
TylerP liked this post
02-13-2020, 07:27 PM #26
Motor was installed on 203 Avenger when new. Just sayin
02-13-2020, 07:57 PM #27
So a fishin motor ,bass mid ,cle, 1 piece plate new?? I know merc has done sum chit tho
02-13-2020, 08:13 PM #28
jus power head from production.. rest is hi perf.. you could get 'em with either bass or offshore can.. both came with one piece adapter, single ram trim.
02-19-2020, 07:32 PM #29Junior Member
- Feb 2020
- Phoenix AZ
- 11
Ok guys parts are in and we will see what happens on Sunday. But my next question is what octane fuel should I use 91? ( this is what I been running) Or is it ok to run 87? Since its a franken-merc not sure if it NEEDS higher octane. Thoughts??????
02-19-2020, 07:50 PM #30
Just stick with 91 if u can.
Merc 2.5 model year
By convincor in forum Technical DiscussionReplies: 7Last Post: 02-18-2018, 11:14 AM -
Need help with 2.5 ss Merc 2005 model
By marcw31 in forum General Boating DiscussionReplies: 2Last Post: 07-20-2008, 06:57 PM -
late model pistons in early model looper???
By BenKeith in forum Technical DiscussionReplies: 3Last Post: 11-25-2001, 12:34 AM -
Merc V-6 Model/size I.D.???
By B.Mac in forum Technical DiscussionReplies: 2Last Post: 07-06-2001, 10:23 AM
